1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: caRepeater: Syntax error: ")" unexpected
To: [email protected]
Date: Wed, 17 May 2017 17:29:25 +0300
Hi.
I've cross-built EPICS base for Raspberry Pi and then built pcaspy on Pi itself and now am trying to run some test apps.
Whenever I try to run caget.pl or caput.pl I get this:
main::(caget.pl:31):    eval { CA->pend_io($opt_w); };
  DB<3> /home/pi/epics/base-3.15.5/bin/linux-arm/caRepeater: 1: /home/pi/epics/base-3.15.5/bin/linux-arm/caRepeater: Syntax error: ")" unexpected
I've trying running both without specifying -w and with -w 10, the result is same.
I'm suspecting that something went wrong during cross-build and am currently looking for alternative ways to build EPICS base.
Meanwhile if you have any idea what this error means or how to properly diagnose it I'd appreciate any help.
Best regards,
Nick.
Prev: soft Timestamp fixed point support william.smith
Next: Re: caRepeater: Syntax error: ")" unexpected nb
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: soft Timestamp fixed point support Andrew Johnson
