Subject: Re: string fanout or stringout after conditional check?
To: [email protected]
Date: Thu, 18 May 2017 15:37:13 +0200
Sorry Ralph for my bad explanation.
Can you give an example of a string, and what records (of which record
types) should have what values after the operation?
That would probably make it clearer.
I have the bar code scanner, so, the string input is the arbitrary ascii and numbers from bar codes, generated by myself, whenever I scan it.
  For example,
  case 1 : user,123456789,U002C007
  case 2 : ABCDEFGHIZ0123456789
  case 3 : office,248795493,M01B21
  case 4 : ....
  case N : SUBMIT
  Note that case 1..N-1 can be done without order.
The scanner has a typical RS232 connection. I wrote the very simple IOC with asyn and Stream. It has only one record and one function in db and proto file as follows:
--- snip snip ---
record(stringin, "$(SYSDEV)RawScanData")
    field(DESC, "RAW Scanned data")
    field(DTYP, "stream")
    field( INP, "@scanner.proto read_raw $(PORT)")
    field(SCAN, "I/O Intr")
    field(PINI, "YES")
read_raw
    in "%s";
--- snip snip ----------
  Is this enough?
   Han
~Ralph
On Thu, May 18, 2017 at 8:53 PM, Jeong Han Lee <[email protected]
<mailto:[email protected]>> wrote:
      I would like to develop the EPICS database in the following situation:
      * Only one stringin input from device,
      * the string as an input has N different types "prefix" in random
    order,
      * The string input should be transferred to relevant PV after
    conditional check.
      I would like to do this with only the existent EPICS DB records if
    it is possible.
      Han
Re: string fanout or stringout after conditional check? Eric Norum
string fanout or stringout after conditional check? Jeong Han Lee
Re: string fanout or stringout after conditional check? Ralph Lange
Prev: Re: string fanout or stringout after conditional check? Ralph Lange
Next: EDM questions lzf neu
Next: Re: string fanout or stringout after conditional check? Eric Norum
