1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: AreaDetector ImageJ viewer problem
Date: Fri, 19 May 2017 14:34:13 +0000
UNRESTRICTED / ILLIMITÉE
I'm trying to use the ImageJ viewer to stream images from an Andor CCD camera and not having much luck. The AreaDetector and its plugins all seem to be working correctly. ImageJ and the EPICS_AD_Viewer plugin seem to be correct and makes the link to the AreaDetector PVs. However whenever I acquire an image the following happens:
  -The ImageJ EPICS_AD_Viewer detects that there is an image and will (usually, if it's timed out from the previous acquire) open an image window. However the window is completely blank.
  -The ImageJ log prints the message "17/5/2017 19:26:41.332: UpdateImage got exception: pendIO timed out"
  -The following exception appears in the window where ImageJ was started:
  May 17, 2017 5:54:48 PM com.cosylab.epics.caj.impl.CATransport processRead
SEVERE:
java.lang.UnsupportedOperationException
        at java.nio.ByteBuffer.array(ByteBuffer.java:994)
        at com.cosylab.epics.caj.impl.handlers.ExceptionResponse.internalHandleResponse(ExceptionResponse.java:130)
        at com.cosylab.epics.caj.impl.handlers.AbstractCAResponseHandler.handleResponse(AbstractCAResponseHandler.java:110)
        at com.cosylab.epics.caj.impl.CAResponseHandler.handleResponse(CAResponseHandler.java:139)
        at com.cosylab.epics.caj.impl.CATransport.processRead(CATransport.java:530)
        at com.cosylab.epics.caj.impl.CATransport.processRead(CATransport.java:412)
        at com.cosylab.epics.caj.impl.CATransport.handleEvent(CATransport.java:350)
        at com.cosylab.epics.caj.impl.reactor.lf.LeaderFollowersHandler.handleEvent(LeaderFollowersHandler.java:77)
        at com.cosylab.epics.caj.impl.reactor.Reactor.processInternal(Reactor.java:400)
        at com.cosylab.epics.caj.impl.reactor.Reactor.process(Reactor.java:284)
        at com.cosylab.epics.caj.impl.reactor.lf.LeaderFollowersHandler.run(LeaderFollowersHandler.java:91)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
        at java.lang.Thread.run(Thread.java:745)
I've tried various combinations with the same result, but I'm currently running ImageJ 1.51 on 64 bit Ubuntu 14.04, and the prebuilt AreaDetector-2-2. I've tried the viewer distributed as part of this prebuilt as well as downloading the latest viewer. EPICS base version is 3-14-12-3.
Thanks in advance for any help.
Mark Vigder
Canadian Neutron Beam Centre
Re: AreaDetector ImageJ viewer problem Mark Rivers
Prev: RE: Question about Edm dynamic display zone's fill color according to PVs Linda.Pratt
Next: Re: AreaDetector ImageJ viewer problem Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
