Subject: Re: How to deal with LINK_ALARM
To: EPICS Tech Talk <[email protected]>
Date: Tue, 6 Jun 2017 11:47:25 -0400
Starting from 3.15, you can set the UDFS (UDF Severity) field to the severity that you want an undefined record to be in.
Cheers,
~Ralph
On Tue, Jun 6, 2017 at 11:14 AM, Mark Rivers <[email protected]> wrote:
Hi Pilar,
First, it is not necessarily a problem that the record has UDF_ALARM after iocInit.  This just means that the hardware value may not be initialized because the record has not yet communicated with the hardware.
There are 2 ways to eliminate the UDF_ALARM at iocInit with asyn device support.
1) For all output records asyn device support attempts to do an initial read of the value from your driver in init_record.  If that read returns ASYN_SUCCESS (0) then the output record VAL field will be initialized based on the value read, and prec->udf will be 0, and there will not be a UDF_ALARM.  This is because the value in your output record is now known to agree with the hardware.  Since your record is in UDF_ALARM I think your driver must be returning an error on that initial read operation.
2) You can set PINI=YES, but that will actually write to the hardware which you may or may not want to do when the IOC boots.
-----Original Message-----
Sent: Tuesday, June 06, 2017 7:05 AM
To: Mark Rivers; [email protected]
Sorry, I have checked it and you are right the alarm is UDF_ALARM.
And in this case ...how is the right way to solve this problem? Setting
field(PINI, "YES") ? Or do I need to check something else?
Sorry I am really new in this field.
Pilar
On 06/06/17 14:00, Mark Rivers wrote:
> Please verify the alarm status using "cainfo" from the shell and "dbpr" from the IOC shell
RE: How to deal with LINK_ALARM Mark Rivers
Re: How to deal with LINK_ALARM Pilar
Prev: RE: Force TCP/IP reconnect from Asyn/Streamdevice Mark Rivers
Next: Channel Access client sees only partial update. Michael Huth
Prev: RE: How to deal with LINK_ALARM Mark Rivers
