Subject: crash in access security when other ioc reboots
To: EPICS <[email protected]>
Date: Tue, 13 Jun 2017 12:04:01 +0200
Hi all,
Maybe someone can help me diagnose this strange problem:
We have one IOC with access security rules using a PV from another IOC. When that other IOC is restarted, this IOC crashes.
Has anyone seen such behavior before?
I am using EPICS base 3.14.12.4.
Here is a stack trace:
#0  0x0fd1e798 in ellDelete (pList=0xb5113d90, pNode=0x10c7e928)
    at ../../../src/libCom/ellLib/ellLib.c:87
#1  0x0ff01f40 in casAccessRightsCB (ascpvt=<optimized out>,
    type=<optimized out>) at ../camessage.c:1111
#2  0x0feadb0c in asComputePvt (asClientPvt=0x10cb02d0)
    at ../asLibRoutines.c:1014
#3  0x0feaddbc in asComputePvt (asClientPvt=0x10cb02d0)
    at ../asLibRoutines.c:959
#4  asComputeAsgPvt (pasg=<optimized out>) at ../asLibRoutines.c:940
#5  0x0feae880 in asComputeAsgPvt (pasg=0x0) at ../asLibRoutines.c:918
#6  asComputeAsg (pasg=0x0) at ../asLibRoutines.c:455
#7  0x0feacd24 in connectCallback (
arg=<error reading variable: value has been optimized out>) at ../asCa.c:99
#8  0x0fdb488c in oldChannelNotify::disconnectNotify (this=0x10a11800,
    guard=...) at ../oldChannelNotify.cpp:112
#9  0x0fda2908 in nciu::unresponsiveCircuitNotify (this=0x10a2b348,
    cbGuard=..., guard=...) at ../nciu.cpp:171
#10 0x0fdac83c in tcpiiu::disconnectAllChannels (this=0x10a51370, cbGuard=...,
    guard=..., discIIU=...) at ../tcpiiu.cpp:1834
#11 0x0fd95a98 in cac::destroyIIU (this=0x10a19808, iiu=...) at ../cac.cpp:1227
#12 0x0fdace54 in tcpSendThread::run (this=0x10a51458) at ../tcpiiu.cpp:229
#13 0x0fd30750 in epicsThreadCallEntryPoint (pPvt=0x10a5145c)
    at ../../../src/libCom/osi/epicsThread.cpp:85
#14 0x0fd37868 in start_routine (arg=0x10412000)
#15 0xb7b9382c in start_thread (arg=0xb04f8480) at pthread_create.c:306
#16 0xb7c9e0e4 in clone () from /lib/libc.so.6
In ellDelete, pNode looks like this:
(gdb) print *pNode
$12 = {next = 0x10c7e838, previous = 0x0}
This crashes when line 87 tries this:
        pNode->previous->next = pNode->next;
I wonder how *pNode could get into this (inconsistent) state?
In casAccessRightsCB, pciu looks like this:
(gdb) print *pciu
$17 = {node = {next = 0x10c7e838, previous = 0x0}, eventq = {node = {
      next = 0x0, previous = 0x0}, count = 0}, client = 0xb5113d50,
  pPutNotify = 0x0, cid = 1, sid = 247215, time_at_creation = {
secPastEpoch = 866178863, nsec = 248388556}, addr = {precord = 0x10777238,
    pfield = 0x107773a0, pfldDes = 0x10035270, no_elements = 1,
    field_type = 9, field_size = 2, special = 0, dbr_field_type = 3},
  asClientPVT = 0x10cb02d0, state = rsrvCS_inService}
For example:
(gdb) print pciu->addr.precord->name
$18 = "SINSB01-RILK-PRE:POWERON", '\000' <repeats 36 times>
This is one of the records using the ASG rule with the external PV.
However pciu->node.previous is NULL which causes the crash.
Also the pciu->node.next points to a structure for a record using thus ASG rule:
print ((struct channel_in_use*)pciu->node.next)->addr.precord->name
$19 = "SINSB01-RILK:MPS-RESET", '\000' <repeats 38 times>
But again here, previous is NULL:
print *pciu->node.next
$20 = {next = 0x10c7e888, previous = 0x0}
Any ideas?
Dirk
Re: crash in access security when other ioc reboots Michael Davidsaver
Prev: Re: IOC Severity Report Ralph Lange
Next: Re: crash in access security when other ioc reboots Michael Davidsaver
Prev: Re: IOC Severity Report Matt Rippa
