Subject: Re: saving samples
To: <[email protected]>
Date: Tue, 13 Jun 2017 11:34:51 -0500
I use an swait record (from synApps calc module: https://github.com/epics-modules/calc) to do this type of thing when the value is a number, not an array. For strings, there is a similar scalcout record.
Here's an example with swait using a random number generator where the current and previous three values are buffered and then averaged.
record(swait, "random_signal") {
    field(DESC, "example random signal")
    field(CALC, "rndm")
record(swait, "memory_example") {
    field(DESC, "average of last four values")
    field(INAN, "random_signal")
    field(INAP, "Yes")
    field(INBN, "memory_example.A")
    field(INBP, "No")
    field(INCN, "memory_example.B")
    field(INCP, "No")
    field(INDN, "memory_example.C")
    field(INDP, "No")
    field(CALC, "(A+B+C+D)/4")
    field(SCAN, "I/O Intr")
Each of the last buffered values is available:
memory_example.A    current value of monitored signal "random_signal"
memory_example.B    previous value of memory_example.A
memory_example.C    previous value of memory_example.B
memory_example.D    previous value of memory_example.C
memory_example.VAL  average of these four values
The swait record provides up to 12 fields (letters A-L): the 11 most recent values could be buffered by extending this example.
HTH,
   Pete
On 06/13/2017 11:06 AM, Miguel Bordalo wrote:
save in another PV the last sample (scalar) (or more samples) of other
PV that is updated periodically.
this is for example: i have the temperature of a room being updated
periodically. I want another PV to act as a buffer that stores the last
two samples of the room's temperature . And i want to be able to acess
them individually of course.
Thanks!
*Miguel Bordalo*
Licenciado em Engenharia Electrotécnica e de Computadores
Instituto Superior Técnico
[email protected] <mailto:[email protected]>
On 13 June 2017 at 16:01, Ralph Lange <[email protected]
<mailto:[email protected]>> wrote:
    Please clarify a bit further.
    What do you mean by "save"?
        Write to a file? Store in an archiver? Write to another record?
    What kind of PV?
        Scalar or array data?
        If array: does "last" mean last array in time, or last element
        in array?
    Cheers,
    ~Ralph
    On Tue, Jun 13, 2017 at 4:18 PM, Miguel
    <[email protected] <mailto:[email protected]>>
    wrote:
        What is the easiest way to save periodicaly the last sample (or
        last 2/3 samples) of a certain PV ?
        ty
 Pete R. Jemian, Ph.D.                <[email protected]>
 Beam line Controls and Data Acquisition, Group Leader
 Advanced Photon Source,   Argonne National Laboratory
 Argonne, IL  60439                   630 - 252 - 3189
    Education is the one thing for which people
       are willing to pay yet not receive.
Re: saving samples Pete Jemian
Re: saving samples Miguel Bordalo
Re: saving samples Ralph Lange
Prev: Re: saving samples Miguel Bordalo
Next: Re: saving samples Pete Jemian
