1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Any issues with Base-3.16.1-rc1?
To: "[email protected]" <[email protected]>, "Johnson, Andrew N." <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 16 Jun 2017 17:11:31 +0000
The use of dbVerify in autosave is just a sanity check before restoring values, so removing the references to dbVerify won't cause any problems unless you are changing the record type of PV's between reboots. Here's a version of dbrestore.c that doesn't do dbVerify checks so you can at least compile and run:
https://raw.githubusercontent.com/epics-modules/autosave/dbrestore-3.16-patch/asApp/src/dbrestore.c
We'll work on replicating this feature for the next autosave release.
From: [email protected] <[email protected]> on behalf of [email protected] <[email protected]>
Sent: Friday, June 16, 2017 10:40:02 AM
To: Johnson, Andrew N.; [email protected]
Subject: RE: Any issues with Base-3.16.1-rc1?
Hi Andrew,
I tried 3.16.1 against our module tree, most build issues looked to be simple ones and covered in the release notes, the only one that wasn't occurred when building autosave asApp. Building this module terminated with a linking error when it couldn't find   dbVerify(), the function is listed in   dbStaticLib.h   but I couldn't see an implementation of it
Freddie
-----Original Message-----
Sent: 02 June 2017 19:46
To: Akeroyd, Freddie (STFC,RAL,ISIS); [email protected]
Hi Freddie,
On 06/02/2017 12:24 PM, [email protected] wrote:
> Base 3.16.1-rc1 compiles OK on Windows 7 x64 with Visual Studio 2015
> and "make runtests" goes through OK too. I haven't had chance to
> integrate it into our full build system yet (i.e. building other epics
> modules against it) but can do that in the next day or so if that
> would be helpful
Thanks for the feedback. I will be creating the final release this afternoon; any issues found now would have to be fixed in a future
3.16.2 release, or in the first release of EPICS 7. There might be a few changes needed in some downstream modules built against this, check the Release Notes for details; these changes should be reported to the respective module maintainers (or to tech-talk).
- Andrew
Arguing for surveillance because you have nothing to hide is no different than making the claim, "I don't care about freedom of speech because I have nothing to say." -- Edward Snowdon
Any issues with Base-3.16.1-rc1? Andrew Johnson
RE: Any issues with Base-3.16.1-rc1? freddie.akeroyd
Re: Any issues with Base-3.16.1-rc1? Andrew Johnson
Prev: Re: Any issues with Base-3.16.1-rc1? Michael Davidsaver
Next: Buffer overflows in MEDM Shuei YAMADA
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Next: seqChanShow oddities when running through procServ Southern, Tim
