Subject: RE: waveform arrays within SNL
To: 'Mark Rivers' <[email protected]>, "'[email protected]'" <[email protected]>
Date: Tue, 20 Jun 2017 21:42:08 +0000
Thx Mark
That works for integer arrays. Not sure why I was previously unsuccessful as I tried various combinations.
But the other waveform record holds an array of strings - field(FTVL,"STRING") – and continues to thwart me.
caput k1:osiris:ss1:posnames "one two three four"
caget k1:osiris:ss1:posnames
k1:osiris:ss1:posnames 4 one two three four
Trrying what I think is correct in SNL, I get compilation errors:
#define MAX_ENTRIES 100
string posnames[MAX_ENTRIES];
assign posnames to "{tel}{instr}:{mech}:posnames";  // this is the ‘string’ waveform record
local variable is:
string names[4] = { "0.100", "0.050", "0.035", "0,020” };
state STARTUP {
entry {
        for (idx=0; idx<4; idx++ ) posnames[idx] = names[idx];
        pvPut( posnames );
error: incompatible types when assigning to type string from type char *
Thx,
Al
Sent: Tuesday, June 20, 2017 9:28 AM
To: Al Honey; '[email protected]'
You need to change it to:
#define MAX_LOCATIONS 1000
int locations[MAX_LOCATIONS];
assign locations to "{tel}{instr}:{mech}:locations";  // where locations is a waveform record with an integer array.
Do you mean a waveform record of type CHAR that is used to hold a long string?  I think you just declare it as
char waveform[MAX_SIZE];
From: [email protected] [mailto:[email protected]] On Behalf Of Al Honey
Sent: Tuesday, June 20, 2017 2:22 PM
To: '[email protected]'
Subject: waveform arrays within SNL
Hi
I cannot find an explicit example in regards to accessing the element values in a waveform array from within an SNL sequencer.
Does anybody have experience doing so?
Can’t seem to do this:
int locations;
int locs[4] = {0,300,600,900};
        pvGet( locations );
        locs = locations;               // is the declaration for locations (above) correct?
error: incompatible types when assigning to type int[4] from type int *
         locs = locations;
This fails too:
         locs[0] = locations[0];
I guess I’m ignorant in regards to accessing the array values in the record.
Also, is it necessary to escape to C in order to update the elements in a waveform string record?
Thanks for any advice you have
Al
Re: waveform arrays within SNL Benjamin Franksen
waveform arrays within SNL Al Honey
RE: waveform arrays within SNL Mark Rivers
Prev: Re: EPICS build system DESTDIR support J. Lewis Muir
Next: areaDetector developers meeting in Aix on Provence Mark Rivers
Prev: RE: waveform arrays within SNL Mark Rivers
Next: Re: waveform arrays within SNL Benjamin Franksen
