Hello EPICS tech-talk,
I am trying to compile an EPICS IOC with libusb included (I
am on a linux platform running ubuntu 14.04 and EPICS base
3.14-3.14.12.3 ).
I created the ioc using
makeBaseApp.pl -t example test
makeBaseApp.pl -t example -i -a linux-x86_64 test
and was able to run make with no issues.
I added the header files for a class I created which interfaces
with a usb device (these are included in this email) by adding
this line to /testAPP/src/testMain.cpp:
#include "DI-2108-P.cpp"
when I try to make, I get this output:
make -C ./configure install
make[1]: Entering directory
`/media/Extra_Space/work/testIOC/configure'
make -C O.linux-x86_64 -f ../Makefile TOP=../.. T_A=linux-x86_64
install
make[2]: Entering directory
`/media/Extra_Space/work/testIOC/configure/O.linux-x86_64'
perl
../../../epics/epics3.14-3.14.12.3/bin/linux-x86_64/convertRelease.pl
checkRelease
make[2]: Leaving directory
make[1]: Leaving directory
make -C ./testApp install
`/media/Extra_Space/work/testIOC/testApp'
make -C ./src install
`/media/Extra_Space/work/testIOC/testApp/src'
make -C O.linux-x86_64 -f ../Makefile TOP=../../..
T_A=linux-x86_64 install
make[3]: Entering directory
`/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64'
/usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE
-Dlinux -D_REENTRANT -O3 -g -Wall -m64 -MMD -I.
-I../O.Common -I. -I.. -I../../../include/os/Linux
-I../../../include
-I../../../../epics/epics3.14-3.14.12.3/include/os/Linux
../testMain.cpp
In file included from ../testMain.cpp:14:0:
../DI-2108-P.cpp: In member function ‘std::vector<double>
DI_2108_P::getReadings()’:
../DI-2108-P.cpp:202:7: warning: variable ‘r’ set but not used
[-Wunused-but-set-variable]
int r; //for return values
/usr/bin/g++ -o test
-L/media/Extra_Space/work/epics/epics3.14-3.14.12.3/lib/linux-x86_64
-L/media/Extra_Space/work/testIOC/lib/linux-x86_64
-m64 test_registerRecordDeviceDriver.o
testMain.o -ltestSupport -lrecIoc -lsoftDevIoc -lmiscIoc
-lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc
-ldbStaticIoc -lca -lCom
testMain.o: In function `DI_2108_P::Initialize()':
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:37:
undefined reference to `libusb_init'
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:42:
undefined reference to `libusb_set_debug'
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:44:
undefined reference to `libusb_get_device_list'
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:51:
undefined reference to `libusb_open_device_with_vid_pid'
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:56:
undefined reference to `libusb_free_device_list'
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:58:
undefined reference to `libusb_kernel_driver_active'
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:63:
undefined reference to `libusb_claim_interface'
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:60:
undefined reference to `libusb_detach_kernel_driver'
testMain.o: In function `DI_2108_P::close()':
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:82:
undefined reference to `libusb_release_interface'
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:89:
undefined reference to `libusb_close'
testMain.o: In function `DI_2108_P::sendMessage(std::string)':
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:114:
undefined reference to `libusb_bulk_transfer'
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:118:
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:120:
undefined reference to `libusb_strerror'
testMain.o: In function `DI_2108_P::getReadings()':
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:208:
testMain.o: In function `DI_2108_P::reset()':
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:74:
undefined reference to `libusb_reset_device'
/media/Extra_Space/work/testIOC/testApp/src/O.linux-x86_64/../DI-2108-P.cpp:90:
undefined reference to `libusb_exit'
collect2: error: ld returned 1 exit status
make[3]: *** [test] Error 1
make[3]: Leaving directory
make[2]: *** [install.linux-x86_64] Error 2
make[1]: *** [src.install] Error 2
make: *** [testApp.install] Error 2
Do you have any idea what might be causing this issue? I've
tried googling around and haven't found anything helpful.
Thank you for your assistance,
-Sam de Jong
#include <bitset>
#include <iostream>
#include <stdio.h>
#include <string.h>
#include <sstream>
#include <unistd.h>
#include <vector>
#include </usr/include/libusb-1.0/libusb.h>
#include "DI-2108-P.h"
using namespace std;
DI_2108_P::DI_2108_P(){
nChan=1;
ranges.resize(nChan);
multiplier.resize(nChan);
divisor.resize(nChan);
DI_2108_P::DI_2108_P(int nChannels){
nChan=nChannels;
void DI_2108_P::Initialize(){
libusb_device **devs; //pointer to pointer of device, used to retrieve a list of devices
//libusb_device_handle *dev_handle; //a device handle
ctx = NULL; //a libusb session
ssize_t cnt; //holding number of devices in list
r = libusb_init(&ctx); //initialize the library for the session we just declared
if(r < 0) {
cout<<"Init Error "<<r<<endl; //there was an error
//return error;
libusb_set_debug(ctx, 3); //set verbosity level to 3, as suggested in the documentation
cnt = libusb_get_device_list(ctx, &devs); //get the list of devices
if(cnt < 0) {
cout<<"Get Device Error"<<endl; //there was an error
//return error;
cout<<cnt<<" Devices in list."<<endl;
dev_handle = libusb_open_device_with_vid_pid(ctx, vID, pID); //these are vendorID and productID I found for my usb device
if(dev_handle == NULL)
cout<<"Cannot open device"<<endl;
else
cout<<"Device Opened"<<endl;
libusb_free_device_list(devs, 1); //free the list, unref the devices in it
if(libusb_kernel_driver_active(dev_handle, 0) == 1) { //find out if kernel driver is attached
cout<<"Kernel Driver Active"<<endl;
if(libusb_detach_kernel_driver(dev_handle, 0) == 0) //detach it
cout<<"Kernel Driver Detached!"<<endl;
r = libusb_claim_interface(dev_handle, 0); //claim interface 0 (the first) of device (mine had jsut 1)
if(r < 0) {
cout<<"Cannot Claim Interface"<<endl;
cout<<"Claimed Interface"<<endl;
void DI_2108_P::reset(){
libusb_reset_device(dev_handle);
void DI_2108_P::close(){
int r;
//libusb_context *ctx = NULL; //a libusb session
r = libusb_release_interface(dev_handle, 0); //release the claimed interface
if(r!=0) {
cout<<"Cannot Release Interface"<<endl;
return;
cout<<"Released Interface"<<endl;
libusb_close(dev_handle); //close the device we opened
libusb_exit(ctx); //needs to be called to end the
string DI_2108_P::sendMessage(string message){
string error = "error";
message = message+"\r";
unsigned char recieved[1000000];
unsigned char sent[50];
strcpy((char*) sent, message.c_str());
int actual; //used to find out how many bytes were written
//cout<<"Data->"<<message<<"<-"<<endl; //just to see the data we want to write : abcd
cout<<"Writing Data..."<<endl;
r = libusb_bulk_transfer(dev_handle, (1 | LIBUSB_ENDPOINT_OUT), sent, sizeof(sent), &actual, 0); //my device's out endpoint was 1, found with trial- the device had 2 endpoints: 2 and 129
if(r == 0 && actual == sizeof(sent)){ //we wrote the 4 bytes successfully
cout<<"Writing Successful!"<<endl;
sleep(0.1);
r = libusb_bulk_transfer(dev_handle, (1 | LIBUSB_ENDPOINT_IN), recieved, sizeof(recieved), &actual, 0);
cout<<actual<<endl;
cout<<libusb_strerror((libusb_error)r)<<endl;
}else
cout<<"Write Error"<<endl;
std::string sName(reinterpret_cast<char*>(recieved));
return sName;
void DI_2108_P::setNChannels(int nChannels){
nChan = nChannels;
void DI_2108_P::setRange(int channel, int range){
if(channel>nChan) return;
if(range>4) return;
ranges[channel] = range;
if(range==0){
multiplier[channel]=10;
divisor[channel] = 1./32768;
}else if(range==1){
multiplier[channel]=5;
}else if(range==2){
multiplier[channel]=2.5;
}else if(range==3){
divisor[channel] = 1./65536;
}else if(range==4){
void DI_2108_P::startScan(){
this->sendMessage("ps 1");
stringstream ss;
for(int i=0; i<nChan; i++){
ss<<i;
string slistString = "slist "+ss.str()+" ";;
ss.str("");
int b=ranges[i]<<8;
int channelMask = i+b;
ss<<channelMask;
slistString = slistString+ss.str();
ss.str("");
this->sendMessage(slistString);
cout<<slistString<<endl;
this->sendMessage("start 0");
void DI_2108_P::stopScan(){
this->sendMessage("stop 0");
vector<double> DI_2108_P::getReadings(){
vector<double> readings;
readings.resize(nChan);
r = libusb_bulk_transfer(dev_handle, (1 | LIBUSB_ENDPOINT_IN), recieved, 1000000, &actual, 0);
short combined = (recieved[2*i+1] << 8 ) | (recieved[2*i] & 0xff);
double add = 0;
if(ranges[i]>2) add=multiplier[i]/2;
readings[i] = multiplier[i]*(double)combined*divisor[i]+add;
return readings;
#include <bitset>
#include <iostream>
#include <stdio.h>
#include <string.h>
#include <sstream>
#include <unistd.h>
#include <vector>
//#include "DI-2108-P.cpp"
class DI_2108_P{
public:
DI_2108_P();
DI_2108_P(int nChannels);
// DI_2108_P(int vendorID, int productID);
void Initialize();
void close();
string sendMessage(string message);
void startScan();
void stopScan();
void reset();
vector<double> getReadings();
void setNChannels(int nChannels);
void setRange(int channel, int range);
private:
static const int vID = 0x0683;
static const int pID = 0x2109;
libusb_context *ctx;
vector<int> ranges;
vector<double> multiplier;
vector<double> divisor;
int nChan;
- RE: Problem compiling EPICS ioc with libusb Mark Rivers
RE: waveform arrays within SNL Al Honey
<2017>
2025
2026
SIS3302 digitizer driver based on Transient Recorder Framework ambroz . bizjak
<2017>
2025
2026
