Subject: RE: PVs disconnected in CSS BOY despite access through caget
To: "Shroff, Kunal" <[email protected]>, "[email protected] >> EPICS Tech Talk" <[email protected]>
Date: Wed, 28 Jun 2017 20:02:55 +0000
I am running 4.3.3-SNAPSHOT.  I implemented the changes you made and appear to be able to manipulate PVs.  Thank you.
Iain.
Sent: Wednesday, June 28, 2017 3:04 PM
To: Iain Marcuson <[email protected]>; [email protected] >> EPICS Tech Talk <[email protected]>
Which version of cs-studio product are you working with? You can find this information under Help -> About
From cs-studio 4.2 onward the configuration of the connection layer is no longer only in the PV configuration page. (We have fixed this in the newer version of cs-studio 4.4 onwards)
In the 4.2-4.3 versions of cs-studio, the configuration of all the ca and pva configuration are under
edit->preferences->core->diirt
here is an example setup for configuring default datasource and channelaccess.
https://github.com/ControlSystemStudio/org.csstudio.nsls2.product/blob/master/features/org.csstudio.nsls2.product.feature/rootfiles/diirt/datasources/datasources.xml
https://github.com/ControlSystemStudio/org.csstudio.nsls2.product/blob/master/features/org.csstudio.nsls2.product.feature/rootfiles/diirt/datasources/ca/ca.xml
Kunal
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Iain Marcuson
Sent: Wednesday, June 28, 2017 2:57 PM
To: [email protected] >> EPICS Tech Talk <[email protected]>
Subject: PVs disconnected in CSS BOY despite access through caget
I am attempting to get a transferred EPICS project working.  The IOC proper seems to be working, and I can access PVs through caget.  However, when I try to access those PVs through CSS BOY, the PVs are all label "Disconnected", including the push buttons.  What might be causing this?
Thank you,
Iain.
PVs disconnected in CSS BOY despite access through caget Iain Marcuson
RE: PVs disconnected in CSS BOY despite access through caget Shroff, Kunal
Prev: RE: PVs disconnected in CSS BOY despite access through caget Shroff, Kunal
Next: Re: Area Detector and high performance NVME devices ulrik.pedersen
Next: archiver quickstart 梁雅翔
