Subject: error during build
To: EPICS Tech Talk <[email protected]>
Date: Tue, 4 Jul 2017 19:03:52 +0530
Hi All,
I am trying to build EPICS on a fresh and upgraded Linux installation.
When I run the make command, the process is stopping with following error messages towards the end
/usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m32 -fPIC -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include ../../../src/libCom/ring/epicsRingPointer.cpp
make[3]: /usr/bin/g++: Command not found
make[3]: *** [epicsRingPointer.o] Error 127
make[3]: Leaving directory `/home/opal/epics/base/src/libCom/O.linux-x86'
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory `/home/opal/epics/base/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `/home/opal/epics/base/src'
make: *** [src.install] Error 2
opal@system1:~/epics/base-linux$
Any clues as to whats going wrong ?
Stefen
RE: error during build Mark Rivers
Prev: device support for Keysight B2962A ? Peter . Mueller
Next: RE: error during build Mark Rivers
