Subject: Re: help - writing a table column from OPI BOY to PV
To: Tomasz Brys <[email protected]>
Date: Wed, 5 Jul 2017 17:28:31 +0200
http://www.aps.anl.gov/epics/tech-talk/2016/msg01173.php
Is this what you're looking for?  To write eg. an array of double?
On 07/05/2017 04:14 PM, Tomasz Brys wrote:
> Hi,
> I need help.
> I have an OPI BOY. I created a table Nx3, (Nrows, 3 columns), N can be from 1 to 200.
> User can modify the table and when is ready press the button to write the whole column of the table to PV
> The PV is type of aao , size 200. Of course, the table can have less than 200 elements.
> What would be the easiest way to do this?
> I tried something like that, create an Action Button and as an action I execute such a script:
> from org.csstudio.opibuilder.scriptUtil import PVUtil
> from array import array
> tab = display.getWidget("Table")
> row = tab.getTable().getRowCount()
> for i in range(1, row):
>    PVUtil.writePV("$(PREFIX):ListVolt", i)  # - this works but write always one element [0]
>    print i
> My question:
> How I can write one column of a table to PV which is type of aao?
> Is it possible to write the whole column at once? Or I have to do it element by element?
> Any help will be appreciated.
> Regards
> Tomasz Brys
> Integrated Control System
> European Spallation Source - ERIC
Re: help - writing a table column from OPI BOY to PV Kasemir, Kay
help - writing a table column from OPI BOY to PV Tomasz Brys
Prev: help - writing a table column from OPI BOY to PV Tomasz Brys
Next: Re: EPICS build system DESTDIR support J. Lewis Muir
Next: Re: help - writing a table column from OPI BOY to PV Kasemir, Kay
