On 07/05, Andrew Johnson wrote:
> On 06/20/2017 03:38 PM, J. Lewis Muir wrote:
> > On top of that, I'm thinking the environment variable approach won't
> > even work on macOS Sierra (and El Capitan too?) with SIP enabled
> > since /bin/sh is a so-called protected process, and [1] says:
> > Spawning children processes of processes restricted by System
> > Integrity Protection, such as by launching a helper process in a
> > bundle with NSTask or calling the exec(2) command, resets the Mach
> > special ports of that child process. Any dynamic linker (dyld)
> > environment variables, such as DYLD_LIBRARY_PATH, are purged when
> > launching protected processes.
> > So, even if DYLD_LIBRARY_PATH was set, it might get removed from the
> > executable's environment by SIP depending on how it gets executed.
> That quotation is discussing launching processes inside a bundle. I
> don't think we would do that — I'm not a MacOS expert, but we don't
> create an EPICS Base bundle for the Mac, so that seems irrelevant to me.
I don't think so. Just invoking /bin/sh from a shell exhibits the
purging of the DYLD_LIBRARY_PATH environment variable. Consider the
following (on macOS Sierra):
% export DYLD_LIBRARY_PATH=a
% echo $DYLD_LIBRARY_PATH
a
% export MY_VAR=b
% echo $MY_VAR
b
% /bin/sh -c 'echo $DYLD_LIBRARY_PATH'
% /bin/sh -c 'echo $MY_VAR'
b
Lewis
- Re: EPICS build system DESTDIR support Andrew Johnson
- Re: EPICS build system DESTDIR support J. Lewis Muir
<2017>
2025
2026
<2017>
2025
2026
