Subject: New releases of many areaDetector modules
Date: Wed, 5 Jul 2017 20:27:33 +0000
New releases of the following areaDetector modules are available.
ADAndor
R2-6 (July 4, 2017)
* Changed from using TinyXml to libxml2.  This is used when saving SPE files.  This change was made
  because ADCore R3-0 no longer includes TinyXml and libxml2 is now available for all platforms in ADSupport.
* Fixed medm screen layout for ADCore R3-0.
ADAndor3
R2-2 (July 4, 2015)
* Fixed configure/RELEASE for IOC.
ADBruker
R2-2 (4-July-2017)
ADCSimDetector
R2-5 (July 4, 2017)
* Update constructor for compatibility with ADCore R3-0.
* Fix medm screen layout for ADCore R3-0.
ADDexela
R2-1 (July 4, 2017)
* Fixed layout of medm screen for ADCore R3-0.
ADFireWireWin
R2-2 (04-July-2017)
ADLightField
R2-4 (04-July-2017)
* Changed layout of medm screen for ADCore R3-0.
* Changed LightField.template to prevent crashes
  - LFExperimentName to PINI=NO so it does load the experiment at startup. This seems to sometimes cause problems.
  - Set LFRepGateWidth.DRVL = 1.e-10 so it cannot be set to 0.
ADMythen
R2-0 (July 4, 2017)
* Driver fixes
  - Allow compiling on Windows
  - Changes to work on big-endian machines
  - Fixed error in writeFloat64; was comparing to NUM_SD_PARAMS, should be FIRST_SD_PARAM
* Fixed medm screen to work with ADCore R3-0
ADPSL
R2-1 (July 4, 2017)
* Many improvements to the driver.  The initial work was done by Adam Bark from Diamond.
  - Worked with Perceval Guillou at Photonic Science to improve the protocol with the server so it is more
    consistent and easier to parse.  Version 4c3 or later of their server is required to work with
    this release of the EPICS driver.
    Photonic Science says that all of their cameras will work with the new server.
    New DLLs will be needed in some cases.
  - Added a CameraName record to select the camera to control.
  - Implemented the asynEnum interface so that mbbo/mbbi records (CameraName, TriggerMode, FileFormat)
    get their choices from a list provided by the server.  This guarantees that the choices will be valid
    for a specific installation and the selected camera.
  - Added support for color cameras.
  - Improved the report() function.
* Finished the PSLDoc.html documentation, converting from marCCD document.
ADPerkinElmer
R2-6 (04-July-2017)
ADPilatus
R2-4 (04-July-2017)
* Only increment NDArrayCounter if the driver got an image.
  When acquiring with `ADNumImages` > 1, `NDArrayCounter`  was immediately incremented before the driver
  confirmed that it actually got an image.
ADPluginEdge
R1-2 (05-July-2017)
* Changed number of arguments passed to NDPluginDriver base class in constructor for ADCore R3-0.
* Changed size of medm screen for new version of NDPluginBase.adl in ADCore R3-0.
ADPointGrey
R2-5 (4-July-2017)
* Updated medm screen layout for ADCore R3-0.
ADProsilica
R2-3 (05-July-2017)
ADPvCam
R2-2 (05-July-2017)
* Commented out Cygwin builds in Makefiles, no longer works.
ADRoper
R2-3 (05-July-2017)
ADSimDetector
R2-6 (July 4, 2017)
* Change startup scripts in iocSimDetector.  st.cmd now loads envPaths and st_base.cmd, so it can be
  run with no copying of files.  st.cmd.linux and st.cmd.windows can still be used for conveniently
  switching host architectures in the same directory by copying envPaths to envPaths.linux or envPaths.windows
  as appropriate.
ADURL
R2-2 (4-July-2017)
* Changed Makefiles to set flags for new version of GraphicsMagick in ADSupport.
* Set SDKVersion and NDDriverVersion in driver.
* Added example GraphicsMagick configuration files (.mgk) to example IOC directory.
* Added some new test TIFF images in the iocURLDriver/images directory.
* Fixed medm files for compatibility with ADCore R3-0.
NDDriverStdArrays
R1-2 (July 5, 2017)
pvaDriver
R1-3 (July 5, 2017)
* Change startup scripts in iocPvaDriver.  st.cmd now loads envPaths and st_base.cmd, so it can be
  as appropriate.
R1-2 (May 9, 2017)
* Reject invalid PV name when creating monitor.
Prev: Re: EPICS build system DESTDIR support Andrew Johnson
Next: Re: EPICS build system DESTDIR support J. Lewis Muir
Prev: Re: help - writing a table column from OPI BOY to PV Michael Davidsaver
Next: Channel Access error under Scientific Linux 7 Abdalla Ahmad
