On 07/05/2017 06:45 PM, Andrew Johnson wrote:
> There are tools which can edit the RPATH setting in an ELF binary, but
> IIRC they can only shorten the path, never make it longer.
There is at least one utility 'patchelf' which does not have this
limitation.
> That's an
> indication to me that what they are doing probably isn't completely
> kosher,
ELF is a fairly complicated format with lots of cross linking between
sections. My guess is that other/older tools don't go to the trouble of
making all the necessary changes to re-layout the section holding the
rpath string.
> and I would rather not rely on arbitrary limits such as the
> length of the RPATH that we first compile in. Until the standard GNU
> binutils programs (objcopy and/or elfedit) provide a way to change an
> RPATH I would be reluctant to use this approach in Base itself.
I won't argue with this reluctance. I also don't like the idea of
supporting something like patchelf. One reason being that this doesn't
help with OSX and Mach binaries.
- Re: EPICS build system DESTDIR support Matt Newville
- Re: EPICS build system DESTDIR support J. Lewis Muir
- Re: EPICS build system DESTDIR support Andrew Johnson
Re: Channel Access error under Scientific Linux 7 Michael Davidsaver
Re: help - writing a table column from OPI BOY to PV Tomasz Brys
<2017>
2025
2026
<2017>
2025
2026
