Dear all,
We would like to announce the release of EPICS Qt release 3.5.1
This is available at https://github.com/qtepics with guidance notes
available at https://qtepics.github.io
The main change in this release is that the QEPlugin library has been split the
into two distinct libraries which are:
QEFramework - the functional library which contains the widgets themselves
together with support functionality. qegui and any other bespoke
display managers programs will need to link against this library.
QEPlugin - strictly the widget plugin library usable by any application using
the ui loader, such as qegui and designer. The QEPlugin library is
dependent on the QEFramework library.
Both libraries are part of the qeframework repository.
The release notes, located at https://qtepics.github.io/release_notes.html , go into
further detail.
Regards
Andrew C. Starritt | Principal Controls Engineer | Australian Synchrotron
p: (03) 8540 4164 | f: (03) 8540 4200 [email protected] | www.synchrotron.org.au 800 Blackburn Road, Clayton, Victoria 3168
| ANJ, 21 Dec 2017 |
Home
News
About
Talk
Base
Modules
Extensions
