1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Autosave for waveform with 1 element
To: "Paduan Donadio, Marcio" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 11 Jul 2017 22:10:10 +0000
Hi Márcio,
Thanks for this.  I see it too, but I don't understand what's causing it.  The aao record also behaves in the same way, but the aSub record does not.
Details:
Using base 3.15.5
When a waveform or aao record's NELM field is set to 1, autosave saves the value of the .VAL field as a scalar, and fails to restore it at boot time. If an aSub record has a field with 1 element, that field value is saved as a scalar and the value is restored correctly at boot time. (All fields restore correctly using run-time restore (fdbrestoreX()), but that's expected, because it's just channel access.)
When I use base 3.14.12.5, all of these fields are restored correctly at boot time.  I tried copying the waveform record from 3.14.12.5 to 3.15.5 and rebuilding, but that doesn't change the behavior of 3.15.5, which suggests to me that the difference is in dbStaticLib.
I think the line in dbrestore.c that isn't doing the same thing under 3.15.5 that it did under 3.14.12.5 is this:
   status = (*dbFastPutConvertRoutine[DBR_STRING][field_type])
where field_type has the value DBF_NOACCESS.  But I don't understand how the aSubRecord's .A field behaves differently than the waveform record's .VAL field, because they are both one element array fields.
For concreteness, here's my database file:
record(waveform, "$(P)s0") {
field(NELM, "1")
field(FTVL,"LONG")
record(waveform, "$(P)s1") {
field(NELM, "1")
field(FTVL,"DOUBLE")
record(aao, "$(P)aao") {
field(NELM, "1")
field(FTVL,"LONG")
record(aSub, "$(P)aSub") {
field(SNAM, "piezoDiffract")
field(FTA, "LONG")
  field(NOA, "1")
Here's my auto_settings.req file:
tmm:s0.VAL
tmm:s1.VAL
tmm:aao
tmm:aSub.A
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] <[email protected]> on behalf of Paduan Donadio, Marcio <[email protected]>
Sent: Friday, July 7, 2017 10:23:01 PM
To: [email protected]
Subject: Autosave for waveform with 1 element
Hello,
here at SLAC, we saw that autosave is failing to recover the data for a waveform with 1 element. For testing purposes, we changed manually NELM to 2 and the recovery succeeded. Another test was to manually edit the sav file, adding the keyword @array@ and the recovering succeeded, too.
I saw the following comment in 5.4.1 release: "Previously, restoring an array which had been saved with zero or one values failed.  Also, manual restore (including restore by configMenu) of any array PV caused a seg fault.".
As we are using 5.7.1, I think this problem is already corrected since 5.4.1. The behavior was observed when using EPICS 3.15.
The strange thing is that the same version of autosave seems to be working in EPICS 3.14, but not in 3.15.
I saw that autosave uses ca_element_count() from the channel access API. Maybe something changed in this function in EPICS 3.15?
Thank you for your help.
Márcio Paduan Donadio
System Control Engineer - SLAC
Re: Autosave for waveform with 1 element Andrew Johnson
Autosave for waveform with 1 element Paduan Donadio, Marcio
Prev: RE: Motor record: No longer issues a stop command when motor already stopped? James.OHea
Next: Re: Autosave for waveform with 1 element Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Autosave for waveform with 1 element Paduan Donadio, Marcio
