Subject: Re: CA gateway with systemd
To: [email protected]
Date: Wed, 12 Jul 2017 16:54:38 +0200
Hey Ben,
I setup the ca gateway using systemd. But I had only one gateway running
on the machine.
Maybe my scripts give you a good starting point!
Best regards,
Florian
On 07/12/2017 03:06 PM, Benjamin Franksen wrote:
> Hello
> Does anyone have an example of how to start the CA PV gateway using
> systemd? Is there a recommended best practice?
> Note: we want to run many gateways on the same machine.
> Cheers
> Ben
| Dr. Florian Feldbauer                |
| Ruhr-Universität Bochum              |
| Experimentalphysik I AG              |
| Universitätsstr 150                  |
| D-44801 Bochum                       |
| Office: NB 2/134                     |
| Phone:  (+49)234 / 32-23563          |
d /var/run/epics 0755 pandadcs pandadcs
[Unit]
Description=EPICS CA Gateway
Requires=network.target
After=network.target
ConditionFileIsExecutable=/opt/epics/bin/cagateway
ConditionPathExists=!/etc/epics/cagateway/not_to_be_run
[Service]
EnvironmentFile=-/etc/default/cagateway
Type=simple
ExecStart="/opt/epics/bin/cagateway -log %h/cagateway.log -cip $CIP -sip $SIP -server -uid %U -gid `id -g %u` -archive -no_cache -home /opt/epics/ca-gateway/ -pvlist $PVLIST -access $ACCESS"
ExecReload=/opt/epics/ca-gateway/gateway.restart
ExecStop=/opt/epics/ca-gateway/gateway.killer
KillMode=process
Restart=on-failure
RestartSec=5s
User=pandadcs
PermissionsStartOnly=true
[Install]
WantedBy=multi-user.target
Re: CA gateway with systemd Florian Feldbauer
CA gateway with systemd Benjamin Franksen
Prev: Re: ioc crashing while using asyn & modbus Mark Rivers
Next: Re: CA gateway with systemd Florian Feldbauer
Prev: CA gateway with systemd Benjamin Franksen
