Hi Ricardo,
On 07/12/2017 04:24 PM, Ricardo Herrero wrote:
> I want to ask you how to compile only for one target architecture in
> EPICS. In the application developer´s guide it is not clear enough . It
> seems as it always compile for host and for other target architectures.
> I want to compile for one target architecture, but not all of them and
> not for the host architecture. I just need to compile for linux-arm in
> any case from a x86_64. How can I do that?
The EPICS Makefile below should build a library and an IOC for linux-arm
but not for the linux-x86_64 host architecture (assuming you built Base
with CROSS_COMPILER_TARGET_ARCHS = linux-arm). You may need to adjust
the TOP variable in the first line depending on how far down the tree
this file is placed, and obviously the source filenames. The important
parts for the target-only build are the setting of the LIBRARY* and
PROD_IOC* variables.
- Andrew
--------------------8<-------------------------
TOP=../..
include $(TOP)/configure/CONFIG
# Build an IOC support library
LIBRARY_linux-arm = testSupport
LIBRARY = $(LIBRARY_$(T_A))
# Compile and add the code to the support library
testSupport_SRCS += libA.c
# Link the library to the EPICS Base libraries
testSupport_LIBS += $(EPICS_BASE_IOC_LIBS)
# Build the IOC application on linux-arm only
PROD_IOC_linux-arm = test
PROD_IOC = $(PROD_IOC_$(T_A))
# test.dbd will be created and installed
DBD += test.dbd
# test.dbd will include these files:
test_DBD += base.dbd
# test_registerRecordDeviceDriver.cpp derives from test.dbd
test_SRCS += test_registerRecordDeviceDriver.cpp
# Build the main IOC entry point where needed
test_SRCS += testMain.cpp
# Link in the code from our support library
test_LIBS += testSupport
# Finally link IOC to the EPICS Base libraries
test_LIBS += $(EPICS_BASE_IOC_LIBS)
include $(TOP)/configure/RULES
- How to compile only for a target architecture Ricardo Herrero
Re: How to compile only for a target architecture Ricardo Herrero
Re: How to compile only for a target architecture Ronald L. Sluiter
<2017>
2025
2026
Re: How to compile only for a target architecture Andrew Johnson
<2017>
2025
2026
