Subject: Re: cross-gcc for vxWorks 5.4.2 on linux
Cc: EPICS Tech-Talk <[email protected]>
Date: Tue, 18 Jul 2017 20:24:48 -0700
Mark,
No, unfortunately it looks like no one here ever built it for linux,
only Solaris.  The reason we're in a jam is that all our Solaris
machines are being retired soon.
If you could send the tar when you get a chance, that would be great.
Thanks very much.
Mike
Michael Dunning
SLAC National Accelerator Laboratory
Accelerator Research Division Test Facilities
2575 Sand Hill Road, MS 63
Menlo Park, CA 94025
+1 (650) 926-5200
On Tue, Jul 18, 2017 at 7:40 PM, Mark Rivers <[email protected]> wrote:
> Hi Michael,
> Do you have an old build of that compiler? If so you may be able to just move your old vxWorks build tree to the new Linux machine without recompiling it. I just tested running our vxWorks 5.4.2 compiler (gcc 2.96) on our new 64-bit Centos 7 system and it seems to work OK.
> If you don't have a built system I could send you a tar ball of ours.
> Mark
> Sent from my iPhone
>> On Jul 18, 2017, at 5:56 PM, Dunning, Michael <[email protected]> wrote:
>> I'm trying to build the cross-gcc cross-compiler for vxWorks 5.4.2
>> (tornado 2.0.2) on linux for a legacy system we have.  At this time,
>> upgrading to a newer version of vxWorks is not an option.
>> I'm using the SNS sources from
>> http://ics-web.sns.ornl.gov/dht/
>> and following the instructions in the README files to configure and build.
>> Version 2.7.2 fails because the gnu.cpp directory appears to be just
>> an empty directory tree.  I'm guessing this is not correct.  Does anyone
>> have another copy of this?
>> Version 2.9.6 fails due to errors that depend on what platform I build
>> it on (I've tried RHEL6 32-bit,
>> RHEL6 64-bit, RHEL5 32-bit).  Has anyone successfully built this on a
>> modern linux platform?
>> Michael Dunning
>> +1 (650) 926-5200
cross-gcc for vxWorks 5.4.2 on linux Dunning, Michael
Re: cross-gcc for vxWorks 5.4.2 on linux Mark Rivers
Prev: Re: cross-gcc for vxWorks 5.4.2 on linux Mark Rivers
Next: Re: Debian packages for debian 9 (stretch) ? Carlos Pascual
Next: Changing AI INP field bob dalesio
