Hi Benjamin,
On 07/18/2017 11:25 AM, Benjamin Franksen wrote:
> One advantage of doing it this way is that we never rely on distributing
> build results for support modules: only the final application that
> builds the IOCs distributes stuff (to the host that runs the IOC). This
> means that dependencies (except for system libraries) are fully handled
> on the build machine.
It occurred to me that for production IOCs maybe we shouldn't be
building shared libraries at all?
Have you compared your approach with just setting STATIC_BUILD=YES in
the IOC application's CONFIG_SITE file? This avoids the need for IOC
executables to be linked to any non-system shared libraries at all, so
you could avoid having to copy them all to your production systems (at
the expense of a larger IOC executable obviously). Since you have
IOC-specific copies of each lib*.so file the OS won't be able to share
them anyway, so you aren't gaining any advantage in exchange for the
overhead of using shared libraries in the first place.
You can set STATIC_BUILD=YES on Linux without the SHARED_LIBRARIES=NO
that Windows needs and you should get the same result, turning off the
build of shared libraries in your Base CONFIG_SITE file would slightly
speed up all module builds. Actually if you set SHARED_LIBRARIES=NO you
don't have to set STATIC_BUILD because the linker will automatically use
the lib*.a files anyway.
The final program link stage for a static build does take longer than
when linking against shared libraries, but you might be giving the
linker a chance to do more whole-program optimization than it can across
shared-library interfaces (I don't know if we actually enable that
optimization though, and of course more optimization means more chances
for optimizer bugs and/or for it to optimize away things that you don't
want it to because you don't know you're relying on undefined behaviour).
- Andrew
- Re: EPICS build system DESTDIR support Mark Rivers
- Re: EPICS build system DESTDIR support Benjamin Franksen
softGlueZynq R2-0, iocZed R2-0 releases Mooney, Tim M.
<2017>
2025
2026
<2017>
2025
2026
