Subject: Re: Time interval for Asyn auto reconnect
To: <[email protected]>
Date: Mon, 31 Jul 2017 10:21:14 -0500
On 07/28/2017 08:46 PM, Paduan Donadio, Marcio wrote:
> The only thing I didn't understand yet is why it is processing
> each 5 seconds and not each 10 seconds.
That's relatively easy if you follow the processing chain in the
database. Removing the fields not related to that, every 10 seconds this
record gets triggered by the SCAN setting:
> record(calcout, "BSOIC:B44:4:GammaAsynControlCount")
>   field(SCAN, "10 second")
>   field(FLNK, "BSOIC:B44:4:GammaAsynControlCheck")
When that processing is finished, the FLNK field processes this:
> record(calcout, "BSOIC:B44:4:GammaAsynControlCheck")
>   field(OOPT, "Transition To Non-zero")
>   field(OUT,  "BSOIC:B44:4:GammaAsynControlReset.PROC PP")
Because that OUT link is marked PP, after writing the value it causes
this record to process:
> record(seq, "BSOIC:B44:4:GammaAsynControlReset")
>   field(LNK2, "BSOIC:B44:4:GammaAsynControl.CNCT PP")
>   field(DLY3, "2")
>   field(LNK4, "BSOIC:B44:4:GammaAsynControl.CNCT PP")
Both of those links are also marked PP, so they will both process this
record, but with at least a 2 second gap (DLY3) in between:
> record(asyn, "BSOIC:B44:4:GammaAsynControl") {
The gap can be more than 2 seconds depending on how long the it took to
process the asyn record the first time (after setting CNT to 0).
HTH,
- Andrew
Time interval for Asyn auto reconnect Paduan Donadio, Marcio
RE: Time interval for Asyn auto reconnect Mark Rivers
Re: Time interval for Asyn auto reconnect Paduan Donadio, Marcio
Re: Time interval for Asyn auto reconnect Mark Rivers
Prev: Re: Time interval for Asyn auto reconnect Paduan Donadio, Marcio
Next: EPICS Redundancy Adil Razzaq
Next: GeniCam support for CamLink cameras Bruce Hill
