1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Replacement for dbGetPdbAddrFromLink ?
To: EPICS Tech-Talk <[email protected]>
Cc: "Condamoor, Shantha" <[email protected]>
Date: Fri, 4 Aug 2017 12:43:53 -0700
I'm failing to come up with a clever way of replacing
dbGetPdbAddrFromLink, which was removed in base 3.15.  It was defined
as a macro in dbAccessDefs.h as this:
#define dbGetPdbAddrFromLink(PLNK) \
( ( (PLNK)->type != DB_LINK ) \
? 0 \
: ( ( (struct dbAddr *)( (PLNK)->value.pv_link.pvt) ) ) )
I can redefine this macro in my source code as the above, but is there
a better way of replacing its functionality, perhaps with a different
macro or function call?
Here's an example of how we were using it:
DBADDR *cntAddr = dbGetPdbAddrFromLink(&psub->inpi);
short *cntP;
long cntNord, offset;
struct rset *prset;
if (!cntAddr) return -1;
dbScanLock(cntAddr->precord);
if ((cntAddr->field_type == DBF_SHORT) && ((prset = dbGetRset(cntAddr)))) {
    cntP = (short *)cntAddr->pfield;
    if (!cntP) cntNord = 0;
    else (*prset->get_array_info)(cntAddr, &cntNord, &offset);
} else {
    cntP    = 0;
    cntNord = 0;
dbScanUnlock(cntAddr->precord);
This is for some rather critical systems, so we're trying at all costs
to avoid surprise runtime errors.
Any suggestions are much appreciated.
Mike
Michael Dunning
SLAC National Accelerator Laboratory
Accelerator Research Division Test Facilities
2575 Sand Hill Road, MS 63
Menlo Park, CA 94025
+1 (650) 926-5200
Re: Replacement for dbGetPdbAddrFromLink ? Stubbs, Scott A.
Prev: Re: Webopi issue with Text Update widget rule Kasemir, Kay
Next: Compile Warning:"Device using undefined record type 'stringin', place-holder created Ricardo Herrero
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Replacement for dbGetPdbAddrFromLink ? Stubbs, Scott A.
