1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Attributes XML problems
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 16 Aug 2017 18:39:34 +0000
Hi Mark,
The PV was on the local IOC, not remote. I checked with caget that PV name was not a typo hence no idea what the deal was..
I can debug some more if you want, but some pointers on what to look at/for would help.
Hinko
On Wed, 16 Aug 2017 at 19:06, Mark Rivers <[email protected]> wrote:
Hi Hinko,
I'm glad that it's working.  I'm curious why HDF5 was not working with  ADCore 2-5.  It should only have failed if the PV could not connect.  Is it possible that was the problem, or should the PV have connected successfully?
Sent: Wednesday, August 16, 2017 11:31 AM
To: Mark Rivers; [email protected]
Thanks a lot.
After updating from 2-5 to latest git release it is much better. No more issues with HDF5 and I can see that updating XML works.
Cheers,
Hinko
On Wed, 16 Aug 2017 at 13:23, Mark Rivers <[email protected]> wrote:
Hi Hinko,
What version of ADCore are you using?
This is from the R3-0 RELEASE.md file:  https://github.com/areaDetector/ADCore/blob/master/RELEASE.md
Fixed a problem with PVAttributes that were not connected to a PV. Previously this generated errors from the HDF5 library because an invalid datatype of -1 was used. Now the data type for such disconnected attributes is set to H5T_NATIVE_FLOAT and the fill value is set to NAN. No data is written from such attributes to the file, so the fill value is used.
This looks might it be the problem you are having, but it should only occur if the PV cannot connect.
> On a related note, can I replace the attribute XML during IOC runtime (while acq is stopped) through 13ANDOR1:cam1:NDAttributesFile PV?
> I would like to edit to add new attributes witout restarting the IOC if possible..
Yes, that is possible.  Note that when you read a new XML file it can add new attributes, but it will normally not delete any existing attributes because they are still attached to the NDArray in the NDArrayPool.  This is explained in this documentation:
http://cars.uchicago.edu/software/epics/areaDetectorDoc.html#NDAttribute<http://cars.uchicago.edu/software/epics/areaDetectorDoc.html#NDAttribute>
The NDAttributeList implements a linked list of NDAttribute objects. NDArray objects contain an NDAttributeList which is how attributes are associated with an NDArray. There are methods to add, delete and search for NDAttribute objects in an NDAttributeList. Each attribute in the list must have a unique name, which is case-sensitive.
When NDArrays are copied with the NDArrayPool methods the attribute list is also copied.
IMPORTANT NOTE: When a new NDArray is allocated using NDArrayPool::alloc() the behavior of any existing attribute list on the NDArray taken from the pool is determined by the value of the global variable eraseNDAttributes. By default the value of this variable is 0. This means that when a new NDArray is allocated from the pool its attribute list is not cleared. This greatly improves efficiency in the normal case where attributes for a given driver are defined once at initialization and never deleted. (The attribute values may of course be changing.) It eliminates allocating and deallocating attribute memory each time an array is obtained from the pool. It is still possible to add new attributes to the array, but any existing attributes will continue to exist even if they are ostensibly cleared e.g. asynNDArrayDriver::readNDAttributesFile() is called again. If it is desired to eliminate all existing attributes from NDArrays each time a new one is allocated then the global variable eraseNDAttributes should be set to 1. This can be done at the iocsh prompt with the command:
    var eraseNDAttributes 1
The NDAttributeList class documentation<http://cars.uchicago.edu/software/epics/areaDetectorDoxygenHTML/class_n_d_attribute_list.html> describes this class in detail.
From: [email protected] [[email protected]] on behalf of Hinko Kocevar [[email protected]]
Sent: Wednesday, August 16, 2017 4:59 AM
To: [email protected]
Subject: Attributes XML problems
I'm trying to set some attributes using XML. If I want to have PV as source HDF5 file saving plugin complains heavily. If I use the parameter as source it is OK.
Example when fine:
<?xml version="1.0" standalone="no" ?>
<!-- Attributes -->
<Attributes
    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
    xsi:noNamespaceSchemaLocation="../../../../../ADCore/XML_schema/NDAttributes.xsd"
    <Attribute name="CameraManufacturer"  type="PARAM"    source="MANUFACTURER"                   datatype="STRING"     description="Camera manufacturer"/>
    <Attribute name="CameraModel"         type="PARAM"    source="MODEL"                          datatype="STRING"     description="Camera model"/>
    <Attribute name="ImageCounter"        type="PARAM"    source="ARRAY_COUNTER"                  datatype="INT"        description="Image counter"/>
    <Attribute name="MaxSizeX"            type="PARAM"    source="MAX_SIZE_X"                     datatype="INT"        description="Detector X size"/>
    <Attribute name="MaxSizeY"            type="PARAM"    source="MAX_SIZE_Y"                     datatype="INT"        description="Detector Y size"/>
    <Attribute name="AcquireTime"         type="PARAM"    source="ACQ_TIME"                       datatype="DOUBLE"     description="Camera acquire time"/>
</Attributes>
Example when bad:
<!-- Attributes -->
<Attributes
    <Attribute name="AcquireTimePV"       type="EPICS_PV" source="13ANDOR1:cam1:AcquireTime_RBV"  dbrtype="DBR_NATIVE"  description="Camera acquire time"/>
</Attributes>
HDF5 file saving complaints:
epics> HDF5-DIAG: Error detected in HDF5 (1.10.0-patch1) thread 139869132080896:
  #000: ../H5Pdcpl.c line 3225 in H5Pset_fill_value(): not a datatype
    major: Invalid arguments to routine
    minor: Inappropriate type
  #000: ../H5D.c line 123 in H5Dcreate2(): not a datatype ID
  #000: ../H5A.c line 265 in H5Acreate2(): not a location
  #001: ../H5Gloc.c line 253 in H5G_loc(): invalid object ID
    minor: Bad value
  #000: ../H5A.c line 634 in H5Awrite(): not an attribute
  #000: ../H5A.c line 1655 in H5Aclose(): not an attribute
    minor: Bad value
    minor: Bad value
    minor: Bad value
  #000: ../H5D.c line 908 in H5Dset_extent(): not a dataset
  #000: ../H5D.c line 375 in H5Dget_space(): not a dataset
  #000: ../H5Shyper.c line 6888 in H5Sselect_hyperslab(): not a data space
  #000: ../H5Dio.c line 225 in H5Dwrite(): not a dataset
  #000: ../H5S.c line 433 in H5Sclose(): not a dataspace
  #000: ../H5D.c line 334 in H5Dclose(): not a dataset
Any ideas?
On a related note, can I replace the attribute XML during IOC runtime (while acq is stopped) through 13ANDOR1:cam1:NDAttributesFile PV? I would like to edit to add new attributes witout restarting the IOC if possible..
Hinko
.. the more I see the less I believe.., AE AoR
RE: Attributes XML problems Mark Rivers
Attributes XML problems Hinko Kocevar
Re: Attributes XML problems Hinko Kocevar
Prev: RE: Help with issue compiling areaDetector Driver Mark Rivers
Next: RE: Attributes XML problems Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Attributes XML problems Mark Rivers
