Subject: Re: CSS-4.5 : Display-Builder : getting widget's PV value
To: Amien Crombie <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Thu, 24 Aug 2017 12:56:26 +0000
Hi:
What's the data type of the PV?
To debug, try adding
  print(str(pv.read()))
and then check in the terminal where you started CSS for the output.
-Kay
From: [email protected] <[email protected]> on behalf of Amien Crombie <[email protected]>
Sent: Thursday, August 24, 2017 4:54 AM
To: EPICS Tech-Talk
Subject: CSS-4.5 : Display-Builder : getting widget's PV value
Hi
My code :
1.     from org.csstudio.display.builder.runtime.script import PVUtil, ScriptUtil
2.     from org.csstudio.display.builder.model.properties import WidgetColor
3.     ss = ScriptUtil.findWidgetByName(widget, "ss_range")
4.     sx = ScriptUtil.findWidgetByName(widget, "rangeX")
5.     pv = ScriptUtil.getPrimaryPV(sx)
6.     pval = PVUtil.getDouble(pv)
7.     ss.setPropertyValue("text", str(pv) + " : " + str(pval))    ##
##  'pv' returns the right pv attached to my 'spinner'. This pv is passed via the script as '$(pv_name)'
##  pval returns 'nan' although my 'spinner' displays the value (1 to 6) depending my last selected value
Thanks
Amien
Re: CSS-4.5 : Display-Builder : getting widget's PV value Amien Crombie
Prev: CSS-4.5 : Display-Builder : getting widget's PV value Amien Crombie
Next: Re: CSS-4.5 : Display-Builder : getting widget's PV value Amien Crombie
