1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Problems building seq 2.2.4 on Linux
To: 'Sue Witherspoon' <[email protected]>, Tech-talk <[email protected]>
Date: Thu, 24 Aug 2017 22:55:02 +0000
Hi Sue,
My apologies, I found that my version of seq 2-2-4 also has a modified version of lemon.c.  Here is the difference
Here is the patch:
[epics@gse-marccd2 lemon]$ diff -U3 lemon.c.orig lemon.c
--- lemon.c.orig        2016-11-25 11:50:21.000000000 -0600
+++ lemon.c     2017-08-24 17:37:51.910633792 -0500
@@ -403,6 +403,7 @@
   char *tokendest;         /* Code to execute to destroy token data */
   char *vardest;           /* Code for the default non-terminal destructor */
   char *filename;          /* Name of the input file */
+  char *outputdir;         /* Name of the output directory */
   char *outname;           /* Name of the current output file */
   char *tokenprefix;       /* A prefix added to token names in the .h file */
   int nconflict;           /* Number of parsing conflicts */
@@ -1576,6 +1577,7 @@
   static int statistics = 0;
   static int mhflag = 0;
   static int nolinenosflag = 0;
+  static char *outputdir = 0;
   static int noResort = 0;
   static struct s_options options[] = {
     {OPT_FLAG, "b", (char*)&basisflag, "Print only the basis in report."},
@@ -1594,6 +1596,7 @@
     {OPT_FLAG, "s", (char*)&statistics,
                                    "Print parser stats to standard output."},
     {OPT_FLAG, "x", (char*)&version, "Print the version number."},
+    {OPT_STR,  "o", (char*)&outputdir, "Directory for output files (default: same as input)."},
     {OPT_FSTR, "T", (char*)handle_T_option, "Specify a template file."},
     {OPT_FSTR, "W", 0, "Ignored.  (Placeholder for '-W' compiler options.)"},
     {OPT_FLAG,0,0,0}
@@ -1614,6 +1617,7 @@
   memset(&lem, 0, sizeof(lem));
   lem.errorcnt = 0;
+  lem.outputdir = outputdir;
   /* Initialize the machine */
   Strsafe_init();
@@ -1725,7 +1729,7 @@
   /* return 0 on success, 1 on failure. */
-  exitcode = ((lem.errorcnt > 0) || (lem.nconflict > 0)) ? 1 : 0;
+  exitcode = (lem.errorcnt > 0);
  exit(exitcode);
   return (exitcode);
@@ -2963,13 +2967,37 @@
   char *name;
   char *cp;
+  char *inputname;
+  int outputdirlen;
+  char *outputdir;
+  outputdir = lemp->outputdir;
+  if (!outputdir) {
+    outputdir = "";
+  outputdirlen = lemonStrlen(outputdir);
+  inputname = strrchr(lemp->filename,'/');
+  if (outputdirlen > 0 && inputname) {
+    inputname += 1;
+  } else {
+    inputname = lemp->filename;
+  name = (char*)malloc( outputdirlen + 1 + lemonStrlen(inputname) + lemonStrlen(suffix) + 1);
-  name = (char*)malloc( lemonStrlen(lemp->filename) + lemonStrlen(suffix) + 5 );
   if( name==0 ){
     fprintf(stderr,"Can't allocate space for a filename.\n");
     exit(1);
-  lemon_strcpy(name,lemp->filename);
+  lemon_strcpy(name,"");
+  if (outputdirlen > 0) {
+    lemon_strcat(name,outputdir);
+    if (outputdir[outputdirlen-1] != '/') {
+      lemon_strcat(name,"/");
+  lemon_strcat(name,inputname);
   cp = strrchr(name,'.');
   if( cp ) *cp = 0;
   lemon_strcat(name,suffix);
When I revert back to lemon.c.orig it fails with the same error you are getting.
I appear to have made that fix on November 25, 2016.
What is strange to me is that I cannot find any e-mail in which this change is discussed, either in my own e-mail or on tech-talk.
Perhaps Ben remembers this fix?  In any event it looks like it a known problems page for 2.2.4 needs to be added here?
http://www-csr.bessy.de/control/SoftDist/sequencer/Installation.html#download
-----Original Message-----
Sent: Thursday, August 24, 2017 3:52 PM
To: Mark Rivers; Tech-talk
Subject: Re: Problems building seq 2.2.4 on Linux
Hi Mark,
    Thanks for your response. The tech-talk thread I was talking about,
which is related (I think) to my problem is :
http://www.aps.anl.gov/epics/tech-talk/2017/msg00087.php  ..
Ben mentions many-core build machines and also GNUmake versions.... I'm
using 'GNU Make 3.81 built for i686-pc-linux-gnu'
But you are right, I am not generating the snl.h  file.
Do you know what rule triggers this generation?
Sue
On 08/24/2017 09:22 AM, Mark Rivers wrote:
> Hi Sue,
> I can't reproduce that problem.
> My system:
> seq 2.2.4
> Redhat 6 (EPICS_HOST_ARCH=linux-x86-rhel6)
> gcc 4.4.7-17
> base 3.15.5
> perl 5.10.1
> I believe I have made only the following change to seq 2.2.4. Tthis was to fix a problem on Windows that was not related to the problem you are seeing.
> corvette:seq-2-2-4/src/snc>diff -U3 snl.lt.orig snl.lt
> --- snl.lt.orig 2017-01-13 08:38:51.976001963 -0600
> +++ snl.lt      2017-01-13 08:35:39.777418847 -0600
> @@ -829,11 +829,11 @@
>       }else if( yyact <= YY_MAX_REDUCE ){
>         yy_reduce(yypParser,yyact-YY_MIN_REDUCE);
>       }else{
> -      assert( yyact == YY_ERROR_ACTION );
> -      yyminorunion.yy0 = yyminor;
>   #ifdef YYERRORSYMBOL
>         int yymx;
>   #endif
> +      assert( yyact == YY_ERROR_ACTION );
> +      yyminorunion.yy0 = yyminor;
>   #ifndef NDEBUG
>         if( yyTraceFILE ){
>           fprintf(yyTraceFILE,"%sSyntax Error!\n",yyTracePrompt);
> When I build seq 2.2.4 with the -sj options it builds fine with only the following output
> [epics@gse-marccd2 seq-2-2-4]$ make -sj clean
> m[epics@gse-marccd2 seq-2-2-4]$ make -sj
> 2 parsing conflicts.
> Your first error is this:
> ../snl.re:16:17: error: snl.h: No such file or directory
> So for some reason it is not finding snl.h.
> Mark
> ________________________________
> From: [email protected] [[email protected]] on behalf of Sue Witherspoon [[email protected]]
> Sent: Tuesday, August 22, 2017 2:59 PM
> To: Tech-talk
> Subject: Problems building seq 2.2.4 on Linux
> Hi,
> I am having problems building seq 2.2.4 on linux:
> Redhat 6 (linux-x86)
> gcc version 4.4.7
> Epics 3.15.5
> perl v5.10.1
> This is the complete output when building.
> devl06 [195]: gmake rebuild
> gmake -C ./configure clean
> gmake[1]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/configure'
> rm -rf O.rhel-6-ia32 O.Common
> gmake[1]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/configure'
> gmake -C ./src clean
> gmake[1]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src'
> gmake -C ./pv clean
> gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/pv'
> gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/pv'
> gmake -C ./common clean
> gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/common'
> gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/common'
> gmake -C ./seq clean
> gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/seq'
> gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/seq'
> gmake -C ./lemon clean
> gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/lemon'
> gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/lemon'
> gmake -C ./snc clean
> gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/snc'
> gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/snc'
> gmake[1]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src'
> gmake -C ./test clean
> gmake[1]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test'
> gmake -C ./compiler clean
> gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test/compiler'
> gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test/compiler'
> gmake -C ./validate clean
> gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test/validate'
> gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test/validate'
> gmake -C ./unit clean
> gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test/unit'
> gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test/unit'
> gmake[1]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/test'
> gmake -C ./examples clean
> gmake[1]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples'
> gmake -C ./cmdButtons clean
> gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/cmdButtons'
> gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/cmdButtons'
> gmake -C ./demo clean
> gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/demo'
> gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/demo'
> gmake -C ./johng clean
> gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/johng'
> gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/johng'
> gmake -C ./simple clean
> gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/simple'
> gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/simple'
> gmake -C ./small clean
> gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/small'
> gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/small'
> gmake -C ./pvGetAsync clean
> gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/pvGetAsync'
> gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples/pvGetAsync'
> gmake[1]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/examples'
> gmake -C ./configure install
> perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/makeMakefile.pl O.rhel-6-ia32 ../..
> mkdir O.Common
> gmake -C O.rhel-6-ia32 -f ../Makefile TOP=../.. \
>          T_A=rhel-6-ia32 install
> gmake[2]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/configure/O.rhel-6-ia32'
> perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/convertRelease.pl checkRelease
> gmake[2]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/configure/O.rhel-6-ia32'
> gmake -C ./src install
> gmake -C ./pv install
> perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/makeMakefile.pl O.rhel-6-ia32 ../../..
> mkdir O.Common
> gmake -C O.rhel-6-ia32 -f ../Makefile TOP=../../.. \
> gmake[3]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/pv/O.rhel-6-ia32'
> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF pv.d  ../pv.c
> gmake[3]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/pv/O.rhel-6-ia32'
> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../pv.c
> /usr/bin/ar -rc    libpv.a        pv.o
> /usr/bin/ranlib libpv.a
> /usr/bin/g++ -o libpv.so.3.15.5 -shared -fPIC -Wl,-hlibpv.so.3.15.5 -L/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/lib/rhel-6-ia32 -L/a/devsite/dvlepics/epics/R3.15.5.J0/lib/rhel-6-ia32 -Wl,-rpath,/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/lib/rhel-6-ia32 -Wl,-rpath,/a/devsite/dvlepics/epics/R3.15.5.J0/lib/rhel-6-ia32           -rdynamic -m32            pv.o    -lca -lCom -Wl,-Bdynamic  -lpthread    -lm -lrt -ldl -lgcc
> Installing shared library ../../../lib/rhel-6-ia32/libpv.so.3.15.5
> ln -s libpv.so.3.15.5 ../../../lib/rhel-6-ia32/libpv.so
> Installing library ../../../lib/rhel-6-ia32/libpv.a
> gmake -C ./common install
> mkdir O.Common
> gmake[3]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/common/O.rhel-6-ia32'
> perl -CSD ../seq_release.pl 2.2.4 > ../O.Common/seq_release.h
> Installing generated generic include file ../../../include/seq_release.h
> gmake[3]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/common/O.rhel-6-ia32'
> gmake -C ./seq install
> mkdir O.Common
> gmake[3]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/seq/O.rhel-6-ia32'
> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF seq_queue.d  ../seq_queue.c
> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF seq_cmd.d  ../seq_cmd.c
> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF seq_qry.d  ../seq_qry.c
> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF seq_prog.d  ../seq_prog.c
> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF seq_mac.d  ../seq_mac.c
> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF seq_if.d  ../seq_if.c
> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF seq_ca.d  ../seq_ca.c
> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF seq_task.d  ../seq_task.c
> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF seq_main.d  ../seq_main.c
> gmake[3]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/seq/O.rhel-6-ia32'
> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../seq_main.c
> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../seq_task.c
> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../seq_ca.c
> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../seq_if.c
> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../seq_mac.c
> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../seq_prog.c
> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../seq_qry.c
> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../seq_cmd.c
> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../seq_queue.c
> /usr/bin/ar -rc    libseq.a        seq_main.o seq_task.o seq_ca.o seq_if.o seq_mac.o seq_prog.o seq_qry.o seq_cmd.o seq_queue.o
> /usr/bin/ranlib libseq.a
> /usr/bin/g++ -o libseq.so.3.15.5 -shared -fPIC -Wl,-hlibseq.so.3.15.5 -L/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/lib/rhel-6-ia32 -L/a/devsite/dvlepics/epics/R3.15.5.J0/lib/rhel-6-ia32 -Wl,-rpath,/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/lib/rhel-6-ia32 -Wl,-rpath,/a/devsite/dvlepics/epics/R3.15.5.J0/lib/rhel-6-ia32           -rdynamic -m32            seq_main.o seq_task.o seq_ca.o seq_if.o seq_mac.o seq_prog.o seq_qry.o seq_cmd.o seq_queue.o    -lpv -lCom -Wl,-Bdynamic  -lpthread    -lm -lrt -ldl -lgcc
> Installing shared library ../../../lib/rhel-6-ia32/libseq.so.3.15.5
> ln -s libseq.so.3.15.5 ../../../lib/rhel-6-ia32/libseq.so
> Installing library ../../../lib/rhel-6-ia32/libseq.a
> gmake -C ./lemon install
> mkdir O.Common
> gmake[3]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/lemon/O.rhel-6-ia32'
> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -MM -MF lemon.d  ../lemon.c
> gmake[3]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/lemon/O.rhel-6-ia32'
> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c ../lemon.c
> /usr/bin/g++ -o lemon -Wl,-Bstatic -L/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/lib/rhel-6-ia32 -Wl,-rpath,/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/lib/rhel-6-ia32           -rdynamic -m32            lemon.o     -Wl,-Bdynamic  -lpthread    -lm -lrt -ldl -lgcc
> Installing created executable ../../../bin/rhel-6-ia32/lemon
> gmake -C ./snc install
> mkdir O.Common
> gmake[3]: Entering directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/snc/O.rhel-6-ia32'
> re2c -s -b -o lexer.c ../snl.re
> perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m lexer.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        lexer.o lexer.c
> perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m builtin.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        builtin.o ../builtin.c
> perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m sym_table.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        sym_table.o ../sym_table.c
> perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m gen_tables.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        gen_tables.o ../gen_tables.c
> perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m gen_ss_code.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        gen_ss_code.o ../gen_ss_code.c
> perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m gen_code.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        gen_code.o ../gen_code.c
> perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m analysis.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        analysis.o ../analysis.c
> perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m var_types.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        var_types.o ../var_types.c
> perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m node.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        node.o ../node.c
> perl -CSD /usr/dvlepics/epics/R3.15.5.J0/bin/rhel-6-ia32/mkmf.pl  -m main.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        main.o ../main.c
> gmake[3]: Leaving directory `/a/devsite/dvlepics/epics/R3.15.5.J0/seq-2.2.4/src/snc/O.rhel-6-ia32'
> /usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_  -DUNIX  -Dlinux     -O3   -Wall           -m32  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/dvlepics/epics/R3.15.5.J0/include/compiler/gcc -I/usr/dvlepics/epics/R3.15.5.J0/include/os/Linux -I/usr/dvlepics/epics/R3.15.5.J0/include        -c lexer.c
> ../snl.re: In function 'scan':
> ../snl.re:330: error: 'TOK_SLASH' undeclared (first use in this function)
> ../snl.re:330: error: (Each undeclared identifier is reported only once
> ../snl.re:330: error: for each function it appears in.)
> ../snl.re:331: error: 'TOK_MOD' undeclared (first use in this function)
> ../snl.re:285: error: 'TOK_NAME' undeclared (first use in this function)
> ../snl.re:287: error: 'TOK_INTCON' undeclared (first use in this function)
> ../snl.re:323: error: 'TOK_PERIOD' undeclared (first use in this function)
> ../snl.re:333: error: 'TOK_GT' undeclared (first use in this function)
> ../snl.re:332: error: 'TOK_LT' undeclared (first use in this function)
> ../snl.re:328: error: 'TOK_ADD' undeclared (first use in this function)
> ../snl.re:327: error: 'TOK_SUB' undeclared (first use in this function)
> ../snl.re:329: error: 'TOK_ASTERISK' undeclared (first use in this function)
> ../snl.re:324: error: 'TOK_AMPERSAND' undeclared (first use in this function)
> ../snl.re:334: error: 'TOK_CARET' undeclared (first use in this function)
> ../snl.re:335: error: 'TOK_VBAR' undeclared (first use in this function)
> ../snl.re:318: error: 'TOK_EQUAL' undeclared (first use in this function)
> ../snl.re:325: error: 'TOK_NOT' undeclared (first use in this function)
> ../snl.re:313: error: 'TOK_SEMICOLON' undeclared (first use in this function)
> ../snl.re:314: error: 'TOK_LBRACE' undeclared (first use in this function)
> ../snl.re:315: error: 'TOK_RBRACE' undeclared (first use in this function)
> ../snl.re:316: error: 'TOK_COMMA' undeclared (first use in this function)
> ../snl.re:317: error: 'TOK_COLON' undeclared (first use in this function)
> ../snl.re:319: error: 'TOK_LPAREN' undeclared (first use in this function)
> ../snl.re:320: error: 'TOK_RPAREN' undeclared (first use in this function)
> ../snl.re:321: error: 'TOK_LBRACKET' undeclared (first use in this function)
> ../snl.re:322: error: 'TOK_RBRACKET' undeclared (first use in this function)
> ../snl.re:326: error: 'TOK_TILDE' undeclared (first use in this function)
> ../snl.re:336: error: 'TOK_QUESTION' undeclared (first use in this function)
> ../snl.re:312: error: 'TOK_NE' undeclared (first use in this function)
> ../snl.re:311: error: 'TOK_EQ' undeclared (first use in this function)
> ../snl.re:308: error: 'TOK_OROR' undeclared (first use in this function)
> ../snl.re:301: error: 'TOK_OREQ' undeclared (first use in this function)
> ../snl.re:300: error: 'TOK_XOREQ' undeclared (first use in this function)
> ../snl.re:307: error: 'TOK_ANDAND' undeclared (first use in this function)
> ../snl.re:299: error: 'TOK_ANDEQ' undeclared (first use in this function)
> ../snl.re:296: error: 'TOK_MULEQ' undeclared (first use in this function)
> ../snl.re:306: error: 'TOK_POINTER' undeclared (first use in this function)
> ../snl.re:305: error: 'TOK_DECR' undeclared (first use in this function)
> ../snl.re:295: error: 'TOK_SUBEQ' undeclared (first use in this function)
> ../snl.re:304: error: 'TOK_INCR' undeclared (first use in this function)
> ../snl.re:294: error: 'TOK_ADDEQ' undeclared (first use in this function)
> ../snl.re:309: error: 'TOK_LE' undeclared (first use in this function)
> ../snl.re:303: error: 'TOK_LSHIFT' undeclared (first use in this function)
> ../snl.re:293: error: 'TOK_LSHEQ' undeclared (first use in this function)
> ../snl.re:310: error: 'TOK_GE' undeclared (first use in this function)
> ../snl.re:302: error: 'TOK_RSHIFT' undeclared (first use in this function)
> ../snl.re:292: error: 'TOK_RSHEQ' undeclared (first use in this function)
> ../snl.re:290: error: 'TOK_FPCON' undeclared (first use in this function)
> ../snl.re:270: error: 'TOK_WHILE' undeclared (first use in this function)
> ../snl.re:269: error: 'TOK_WHEN' undeclared (first use in this function)
> ../snl.re:268: error: 'TOK_VOID' undeclared (first use in this function)
> ../snl.re:267: error: 'TOK_UNSIGNED' undeclared (first use in this function)
> ../snl.re:266: error: 'TOK_UNION' undeclared (first use in this function)
> ../snl.re:277: error: 'TOK_UINT32T' undeclared (first use in this function)
> ../snl.re:275: error: 'TOK_UINT16T' undeclared (first use in this function)
> ../snl.re:273: error: 'TOK_UINT8T' undeclared (first use in this function)
> ../snl.re:264: error: 'TOK_TO' undeclared (first use in this function)
> ../snl.re:265: error: 'TOK_TYPENAME' undeclared (first use in this function)
> ../snl.re:257: error: 'TOK_SS' undeclared (first use in this function)
> ../snl.re:263: error: 'TOK_SYNC' undeclared (first use in this function)
> ../snl.re:261: error: 'TOK_SYNCQ' undeclared (first use in this function)
> ../snl.re:260: error: 'TOK_STRUCT' undeclared (first use in this function)
> ../snl.re:259: error: 'TOK_STRING' undeclared (first use in this function)
> ../snl.re:258: error: 'TOK_STATE' undeclared (first use in this function)
> ../snl.re:256: error: 'TOK_SIZEOF' undeclared (first use in this function)
> ../snl.re:255: error: 'TOK_SHORT' undeclared (first use in this function)
> ../snl.re:254: error: 'TOK_RETURN' undeclared (first use in this function)
> ../snl.re:253: error: 'TOK_PROGRAM' undeclared (first use in this function)
> ../snl.re:252: error: 'TOK_OPTION' undeclared (first use in this function)
> ../snl.re:251: error: 'TOK_MONITOR' undeclared (first use in this function)
> ../snl.re:250: error: 'TOK_LONG' undeclared (first use in this function)
> ../snl.re:248: error: 'TOK_IF' undeclared (first use in this function)
> ../snl.re:249: error: 'TOK_INT' undeclared (first use in this function)
> ../snl.re:272: error: 'TOK_INT8T' undeclared (first use in this function)
> ../snl.re:276: error: 'TOK_INT32T' undeclared (first use in this function)
> ../snl.re:274: error: 'TOK_INT16T' undeclared (first use in this function)
> ../snl.re:246: error: 'TOK_FOR' undeclared (first use in this function)
> ../snl.re:247: error: 'TOK_FOREIGN' undeclared (first use in this function)
> ../snl.re:245: error: 'TOK_FLOAT' undeclared (first use in this function)
> ../snl.re:244: error: 'TOK_EXIT' undeclared (first use in this function)
> ../snl.re:243: error: 'TOK_EVFLAG' undeclared (first use in this function)
> ../snl.re:242: error: 'TOK_ENUM' undeclared (first use in this function)
> ../snl.re:241: error: 'TOK_ENTRY' undeclared (first use in this function)
> ../snl.re:240: error: 'TOK_ELSE' undeclared (first use in this function)
> ../snl.re:239: error: 'TOK_DOUBLE' undeclared (first use in this function)
> ../snl.re:238: error: 'TOK_CONTINUE' undeclared (first use in this function)
> ../snl.re:237: error: 'TOK_CONST' undeclared (first use in this function)
> ../snl.re:236: error: 'TOK_CHAR' undeclared (first use in this function)
> ../snl.re:235: error: 'TOK_BREAK' undeclared (first use in this function)
> ../snl.re:234: error: 'TOK_ASSIGN' undeclared (first use in this function)
> ../snl.re:298: error: 'TOK_MODEQ' undeclared (first use in this function)
> ../snl.re:297: error: 'TOK_DIVEQ' undeclared (first use in this function)
> ../snl.re:358: error: 'TOK_STRCON' undeclared (first use in this function)
> ../snl.re:427: error: 'TOK_CCODE' undeclared (first use in this function)
> gmake[3]: *** [lexer.o] Error 1
> gmake[2]: *** [install.rhel-6-ia32] Error 2
> gmake[1]: *** [snc.install] Error 2
> gmake: *** [src.install] Error 2
> devl06 [196]:
> I saw a thread in tech-talk that appeared to address this but after applying the same fix to src/snc/Makefile  by adding: HDEPENDS_METHOD=MKMF, I still get the error.  snl.h is not being generated......
> Any help would be most appreciated!
> Sue Witherspoon
> Staff Computer Scientist
> Accelerator Controls Software
> 757-269-7579
> Thomas Jefferson National Accelerator Facility
Sue Witherspoon
757-269-7579
Re: Problems building seq 2.2.4 on Linux Ben Franksen
Problems building seq 2.2.4 on Linux Sue Witherspoon
RE: Problems building seq 2.2.4 on Linux Mark Rivers
Re: Problems building seq 2.2.4 on Linux Sue Witherspoon
Prev: Re: Problems building seq 2.2.4 on Linux Sue Witherspoon
Next: Re: Problems building seq 2.2.4 on Linux Ben Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
