1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: FTP server on Linux(Ubuntu)
To: Amit Chauhan <[email protected]>
Date: Fri, 1 Sep 2017 10:13:59 -0500
Dear Amit
	I think the problem is that ‘vsftpd’ FTP service - it likely requires authentication, security, protocols the VME machines are not up to.
Here at LIGO, we successfully transitioned some really old VME/VxWorks machines from a Solaris file server to [eventually] an Ubuntu 12.04LTS machine running nfs-kernel-server and rsh-redone-server.  We enter the machine in an rhosts table.
My limited check of ‘vsftpd’ says it is ‘Very Secure FTP Daemon’  I would start by using a more vanilla server like nfs-kernel-server
	Keith Thorne
> On Sep 1, 2017, at 7:12 AM, Amit Chauhan <[email protected]> wrote:
> Hello,
> This is regarding use of FTP server on a Linux (Ubuntu) PC.
> I am trying to use an Ubuntu 14.04 PC as an FTP server by using the 'vsftpd' application.
> The client is a VME based CPU running vxWorks that needs to download kernel image over FTP.
> This client is getting served when I am using a Windows based FTP server.
> But somehow the FTP connection is not getting established between the VME client and Ubuntu based server.
> The error messages I get on client side are like :
> FTP Transfer Failed
> Error Code = 0x3d  (ECONNREFUSED)
> I googled about the problem and tried a few suggestion of making changes in the vsftpd.conf file , but to no avail.
> Also I do not see any entry in the log file on the server (/var/log/vsftpd.log)
> The FTP service seems to be running on the PC as I get a task ID. Also when I type the command 'ftp <self IP-address>' in a terminal , I get the 'ftp>' prompt.
> Has anybody successfully used the vsftpd on Ubuntu (or Linux in general) PC to server an external VME like client ?
> Thanks,
> Amit
Keith Thorne <[email protected]>
CDS Software Engineer
LIGO Livingston Laboratory
Livingston, LA 70754
Phone: (225)686-3168 Fax: (225)686-7189
RE: FTP server on Linux(Ubuntu) Mark Rivers
FTP server on Linux(Ubuntu) Amit Chauhan
Prev: C++ multi threaded application. Giacomo S.
Next: RE: FTP server on Linux(Ubuntu) Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: FTP server on Linux(Ubuntu) Amit Chauhan
