1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Base 3.15 and record initialization
To: "Dunning, Michael" <[email protected]>, EPICS Tech-Talk <[email protected]>
Cc: "Condamoor, Shantha" <[email protected]>
Date: Sat, 2 Sep 2017 01:28:28 -0700
Hi Mike,
I dug further into this and found that in 3.14.12 and earlier, the call to inherit_severity() in dbGetLinkValue() in dbAccess.c has this test for DB_LINKs to block records from inheriting severity from themselves:
        if(precord!= paddr->precord) {
            inherit_severity(ppv_link,precord,paddr->precord->stat,paddr->precord->sevr);
In 3.15.5, that code has moved to dbLink.c and the equivalent call to inherit_severity()
in dbGetLink() doesn't have that test.
This is another indication that the use of "MS" in your calc records was probably not intentional
and likely didn't behave different than if "NMS" had been used, so it should be safe for you to
make that change.
For the community, the question is whether or not this is correct behavior and if there is a use
case for a record inheriting severity from itself.    I can't think of one.
- Bruce
On 09/01/2017 04:21 PM, Dunning, Michael wrote:
We're upgrading some IOCs to base 3.15.5, and are seeing some new behavior with self-referential calc records.  Here's a simplified example:
record(ao, "TEST123:AoTest") {
  field(HIGH, "5")
  field(HIHI, "10")
  field(HSV,  "MINOR")
  field(HHSV, "MAJOR")
  field(PINI, "1")
  field(FLNK, "TEST123:CalcTest")
record(calc, "TEST123:CalcTest") {
  field(INPA, "TEST123:CalcTest NPP MS")
  field(INPB, "TEST123:AoTest NPP MS")
  field(CALC, "B<100?(A+1):A")
  field(FLNK, "TEST123:AiTest")
record(ai, "TEST123:AiTest") {
  field(INP,  "TEST123:CalcTest")
  field(HIGH, "5")
  field(HIHI, "10")
  field(HSV,  "MINOR")
Notice the "MS" in the calc record's INPA.  We don't yet know why the original developer did this, and it seems that it would just cause the record to get stuck in an alarm state if any input went into an alarm state.
Also notice that the calc record gets processed by the ao record, so it's not an issue of anything being undefined.
With base 3.15.5, when the IOC starts, the calc record has SEVR: INVALID and STAT: LINK.
If I change INPA from "MS" to "NMS" and restart the IOC, the record has SEVR: NO_ALARM and STAT: NO_ALARM.
I verified that with base 3.14.11 and 3.14.12 the problem doesn't happen; i.e. the record has SEVR: NO_ALARM and STAT: NO_ALARM.
Can anyone comment on whether we can safely replace "MS" with "NMS" in a record chain like this?  And if there have been more significant changes to the way that records are initialized, should we expect anything else to break?
Mike
Michael Dunning
SLAC National Accelerator Laboratory
2575 Sand Hill Road, MS 63
Menlo Park, CA 94025
Bruce Hill
Member Technical Staff
2575 Sand Hill Road M/S 10
Re: Base 3.15 and record initialization Johnson, Andrew N.
Base 3.15 and record initialization Dunning, Michael
Prev: Base 3.15 and record initialization Dunning, Michael
Next: Re: Base 3.15 and record initialization Andreas Lüdeke
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Base 3.15 and record initialization Johnson, Andrew N.
