1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Cannot communicate with S7-400
To: "Antal, Szabolcs" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 12 Sep 2017 12:17:35 +0000
Well, I managed to solve it.
Needed to add this line to the /etc/hosts file of the VM:
192.168.1.108 PLC1
Where 192.168.1.108 is the ip address of the CP card and PLC1 is the name of the s7plc driver configuration.
After that I could query the status of the PLC and also the real variable I wanted, but still for some reason
the PLC cannot get the real value that my IOC sends to it. So that one is still in progress.
Yours truly,
____________________
Szabolcs Antal
Software Developer
cid:companylogo
evopro systems engineering Kft.
member of the evopro group
HU-4031, Debrecen, Köntösgátsor 1-3. Daniella Ipari Park
www.evopro-group.com
Mobile: +36 30 310 0367
From: [email protected] [mailto:[email protected]] On Behalf Of Antal, Szabolcs
Sent: Tuesday, September 12, 2017 7:51 AM
To: [email protected]
Subject: Cannot communicate with S7-400
Dear Folks,
I’m trying to set up an Ethernet send/recv communcation between a S7 417-4 CPU with CP443-1 communication interface and
a simple EPICS IOC.
To create the S7 project I followed the instructions from this page http://epics.web.psi.ch/software/s7plc/ and also I use the device driver provided here.
My S7 project compiles and can be downloaded to the PLC and runs without any problem.
From the IOC side I did build the s7plc device driver and also configured it in the st.cmd script together with the substitution and template files.
After starting the IOC with softIoc st.cmd command, it’s being successfully initialized and is running, but then the communication timeout elapses and I get the following
error messages:
s7plcWaitForInput PLC1: select(5, 2.000000 sec) timed out
s7plcReceiveThread PLC1: read error after 0 of 4 bytes: Connection timed out
I’m sending a single float and also expecting another single float variable to recieve that’s why I set a length of 4 bytes.
Also when I ping the PLC from the EPICS VM’s terminal I got responses without any loss so the communication should be fine between the systems.
I guess I’m missing some settings or maybe I’m completely doing it wrong as I’m kinda new to EPICS so any help would be appreciated!
I can also send the S7 project and the EPICS IOC files for further troubleshooting if required!
Thank you all!
Yours truly,
Szabolcs Antal
Software Developer
cid:companylogo
Ez az e-mail (ideértve annak bármely mellékletét) bizalmas információkat tartalmaz és jogi védelem alatt áll. Az üzenet kizárólag a címzett(ek)nek szól. Amennyiben Ön nem a küldemény címzettje, úgy a téves kézbesítést kérjük haladéktalanul jelezze e-mailben a feladónak és a teljes küldeményt helyreállíthatatlanul törölje. Amennyiben Ön nem az üzenet címzettje, kérjük ne készítsen másolatot az üzenetről, ne továbbítsa, ne tárja fel és ne tegye hozzáférhetővé azt más személy(ek) számára, továbbá semmilyen célra ne használja fel a bizalmas információt: ezen magatartások bármelyike a levéltitok megsértésének minősül.
Information in this e-mail (including any attachment hereto) is confidential and may be legally privileged. It is intended solely for the attention of the addressee(s). If you received this message in error, please immediately notify the sender by return e-mail and irrecoverably delete the whole message. If you received this e-mail in error, please do not copy it, do not forward, disclose or make it available to other person(s), and do not use the confidential information for any purpose: any such action is regarded as a breach of confidence.
Cannot communicate with S7-400 Antal, Szabolcs
Prev: How to use Archiver Appliance to archive PVs of only the latest period of time Wang, Lin
Next: Re: Automatic refresh of OPI Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Cannot communicate with S7-400 Antal, Szabolcs
Next: releasing support for Beckhoff KL2541 motor driver Davide Marcato
