1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Questions regarding CA protocol specification and phylosophy
To: Dirk Zimoch <[email protected]>
Date: Wed, 13 Sep 2017 17:05:49 +0200
First of all, thanks a lot
Starting for the configuration: the 2 IOCs and the EPICS client is in the same Host, no firewall...
If I understood correctly, every IOC, shall be working in different IPs on different subnetworks? e.g.,
IOC1 on 192.168.0.2
IOC2 on 192.168.1.3
and client shall have access to booth IPs....
So then, the configuration as follows is not correct:
all of them working on 127.0.0.1
Is well understood?
Thanks a lot
Diego
2017-09-13 16:26 GMT+02:00 Dirk Zimoch <[email protected]>:
On 13.09.2017 16:03, Kasemir, Kay wrote:
The main issue here is not TCP but UDP.
Just for completeness: TCP can be an issue as well if you have a firewall between client and IOC. Even if if you tell the firewall to allow the CA ports for UDP and TCP then the search broadcast may pass, maybe even the reply reaches the client, but you still may not be able to connect to the dynamically assigned TCP port of the second IOC.
Dirk
Re: Questions regarding CA protocol specification and phylosophy Kasemir, Kay
Re: Questions regarding CA protocol specification and phylosophy Michael Davidsaver
Questions regarding CA protocol specification and phylosophy Diego Sanz
Re: Questions regarding CA protocol specification and phylosophy Dirk Zimoch
Prev: Re: Questions regarding CA protocol specification and phylosophy Michael Davidsaver
Next: RE: Help creating motorR6-9 examples Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Questions regarding CA protocol specification and phylosophy Dirk Zimoch
Next: Re: Questions regarding CA protocol specification and phylosophy Kasemir, Kay
