1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Enumerated Strings in CSS BOY
To: EPICS Tech Talk <[email protected]>
Date: Thu, 21 Sep 2017 17:45:30 +0000
My software queries a status value from a sensor.  I want to display the status as a string in my OPI.  The status values are neither sequential nor zero-indexed.  I tried to create an mbbi record with the *VL and *ST fields set to match the status string with the status value.  CSS BOY, however, does not display the string matching the mbbi VAL number, but the *ST field corresponding to the VAL number.  For example:
Field(ONVL, 129)
Field(ONST,"Done")
Field(THVL,1)
Field(THST,"Clearing")
If the mbbi VAL field is 1, then CSS BOY will display "Done" as opposed to "Clearing".
What is the preferred way of outputting a string with such an enum?
Thank you,
Iain.
Re: Enumerated Strings in CSS BOY Andrew Johnson
Prev: Re: APS Firewall Ralph Lange
Next: Re: Enumerated Strings in CSS BOY Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
