1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: PCASpy 0.7
To: Epics <[email protected]>
Date: Thu, 21 Sep 2017 19:26:54 +0000
Here I put out a new release of PCASpy. The reason for this minor version bump is the incompatible changes:
    * Changed :meth:`gdd.get` to return empty string if char(int8/uin8) typed scalar is 0. It used to return ``'\x00'``, this confuses the check for an empty string.
    * Changed :meth:`Driver.setParam` so that waveform PV always posts monitor/archive events. It used to check the equality.
Also new features get added,
    * Fixed numpy array checking. (Issue #44)
    * Added adel/mdel fields in scalar PV configuration in analog to EPICS IOC records. (Issue #46)
    * Added :meth:`Driver.getParamInfo` to retrieve the current PV configuration. (PR #45)
    * Added an example *rpi_gpio.py* to control GPIO on RaspberryPi.
The binary packages should appear shortly at PyPI and anaconda paulscherrerinstitute channel.
Thanks all for the bug reports and pull requests.
Best
Xiaoqiang
Prev: RE: Enumerated Strings in CSS BOY Iain Marcuson
Next: quadEM R9-0 now available Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
