1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: measComp R1-4 released
To: tech-talk <[email protected]>
Date: Fri, 22 Sep 2017 14:32:50 +0000
Folks,
Release 1-4 of the measComp module is now available.
This is from the release notes:
- Added support to drvMultiFunction for the USB-1608G.
  This is similar to the previously supported USB-1608GX-2A0 except that it is 250 kHz vs 500 kHz, and does not have the 2 analog output ports.
- Added support for new version of USB-1608GX-2A0 which is functionally the same but has a different board type identifier.
- Renamed the iocBoot/iocUSB1608G to iocUSB1608G-2A0, and added new iocUSB1608 directory for the USB-1608G.
- Added support to drvMultiFunction for the USB-231, and a new iocUSB231 directory.
- Removed parameter counting and NUM_PARAMS argument to asynPortDriver constructor in all drivers. These are not needed in asyn R4-32.
The home page for measComp is here:
http://cars.uchicago.edu/software/epics/measComp.html
The documentation is here:
http://cars.uchicago.edu/software/epics/measCompDoc.html
The release notes are here:
http://cars.uchicago.edu/software/epics/measCompReleaseNotes.html
The source repository is on Github:
https://github.com/epics-modules/measComp
Cheers,
Prev: quadEM R9-0 now available Mark Rivers
Next: Control System Engineer Opening at Lawrence Berkeley Laboratory Robert Gunion
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
