Subject: Re: Archiver: Problems with disconnected PVs
To: Dirk Zimoch <[email protected]>, <[email protected]>
Date: Mon, 25 Sep 2017 17:32:54 +0200
On 09/01/2017 04:07 PM, Dirk Zimoch wrote:
> We have already started thinking about a different CA connection model.
> Since the archiver is a well known client, it should be possible to
> initiate the CA connection from the IOC to the archiver instead of the
> other way round. This would not require any broadcasts and remove the
> need for an archiver configuration file with an up-to-date record list.
> But it would need some programming effort.
Interesting idea. Does pvAccess support such a model?
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Attachment: signature.asc
Description: OpenPGP digital signature
Re: Archiver: Problems with disconnected PVs Andrew Johnson
Archiver: Problems with disconnected PVs Gabriel de Souza Fedel
Re: Archiver: Problems with disconnected PVs Dirk Zimoch
Prev: Re: Coordinated motion with EPICS motor record Henrique Almeida
Next: Re: Spurious "Channel write request failed" messages Andrew Johnson
Prev: Re: Archiver: Problems with disconnected PVs Dirk Zimoch
Next: Re: Archiver: Problems with disconnected PVs Andrew Johnson
