can I save an array of floats into HDF5 file through areaDetector Attribute? XML definition: <Attribute name="GaussParams" type="EPICS_PV" source="DTU:GaussParams" dbrtype="DBR_NATIVE" description="Gauss params"/> where PV is: record(waveform, "$(P)$(R)GaussParams") { field(FTVL, "DOUBLE") field(NELM, "10") } With the above, I only a single (first) value saved in the HDF5 file as opposed to all 10. Thanks, Hinko .. the more I see the less I believe.., AE AoR
| ANJ, 21 Dec 2017 |
Home
News
About
Talk
Base
Modules
Extensions
