Thanks very much for the quick reply. And especially for the example code!
> On Sep 26, 2017, at 8:27 AM, Goetze, Kurt A. <[email protected]> wrote:
> Hi Eric,
> According to PI, this controller uses the "PI General Command Set" (GCS). So motorApp/PIGCS2Src should work. PI wrote this driver, so they should be able to help you if you if this code needs to be updated. They have been helpful in the past. Our contact at PI is Steffen Rau.
> On Sep 26, 2017, at 8:27 AM, Roehrig, Christian <[email protected]> wrote:
> Hi Eric,
> I am using these stages with driver from the PIGCS2Src directory in the motor module. Here are the contents of the file I load at boot time.
Eric Norum
[email protected]
- PI E-873 motors Eric Norum
- Re: PI E-873 motors Roehrig, Christian
RE: PI E-873 motors Goetze, Kurt A.
Re: EPICS base startup directory in an installation location. Andrew Johnson
<2017>
2025
2026
<2017>
2025
2026
