Subject: Re: Question about epics/Labview and Ca Lab -- how to put time to my PV from signal waveform chart in labview.
To: <[email protected]>
Date: Wed, 27 Sep 2017 12:07:49 +0200
Hello Zhefu,
your EPICS PV "caLab:waveDouble" already has a "native" EPICS time stamp. It will be automatically generated. You can see it when you set up a camonitor session. If this time stamp is unacceptable then you can write any time stamp to a second EPICS PV at same time (CA Lab can take a array of PV names to write to; see examples at homepage). But remember it won't be a consistent data set because of delay difference of data transmissions.
Best regards
Carsten
Example solution:
Am 26.09.2017 um 15:27 schrieb lzf neu:
hi,
I want to put the signal waveform chart versus time to my PV from labview, and camonitor the PV in epics terminal.
I install Calab software to do this. As can be seen from the test.vi file in the attatchment. I could put waveform values (values of Y axis of chart by using NI-Scope widget) to my epics PV ("caLab:waveDouble") by using "Ca Lab epics put " widget.
My problem is that I have no idea how to put time (values of X axis of chart) to another PV by using
"Ca Lab epics put " widget or any other methods, so I can camonitor the PV in epics terminal.
I have attatched the labview file (test.vi) in the attatchement, any help will be appreciated and thanks in advance.
Zhefu
Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech (kommissarisch), Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Question about epics/Labview and Ca Lab -- how to put time to my PV from signal waveform chart in labview. lzf neu
Prev: issue with epics in python Cyrille Thomas
Next: registerRecordDeviceDriver.pl takes a long time to finish Hinko Kocevar
Prev: Question about epics/Labview and Ca Lab -- how to put time to my PV from signal waveform chart in labview. lzf neu
Next: EPICS base startup directory in an installation location. Jeong Han Lee
