So the problem seems to be related to the Perl version (5.18 is OK, 5.20 got much slower), and maybe to our DBD file parser reading large DBD files into memory. Since I can replicate this now I hope to be able to make it so that our code isn’t so badly affected.
- Andrew
> On Sep 27, 2017, at 11:16 AM, Henrique Almeida <[email protected]> wrote:
> Hello, I can confirm the same problem on Ubuntu 16.04 and EPICS base 3.16.
> 2017-09-27 12:32 GMT-03:00 Johnson, Andrew N. <[email protected]>:
>> Hi Hinko,
>> On Sep 27, 2017, at 5:15 AM, Hinko Kocevar <[email protected]> wrote:
>>> Under 3.15.4 perl script execution takes a lot of time on Linux Mint, while it executes in a jiffy on CentOS.
>>> I added a time in front of the perl call in RULES.db:
>>> time perl -CSD /devel/root/R3.15.4/base/bin/linux-x86_64/registerRecordDeviceDriver.pl -I. -I.. -I../O.Common -I../../../dbd -I/devel/root/R3.15.4/modules/adcore-master/dbd -I/devel/root/R3.15.4/modules/adsimdetector-master/dbd -I/devel/root/R3.15.4/modules/asyn-master/dbd -I/devel/root/R3.15.4/modules/autosave-master/dbd -I/devel/root/R3.15.4/modules/busy-master/dbd -I/devel/root/R3.15.4/modules/calc-master/dbd -I/devel/root/R3.15.4/modules/sscan-master/dbd -I/devel/root/R3.15.4/base/dbd -o simDetectorApp_registerRecordDeviceDriver.cpp ../O.Common/simDetectorApp.dbd simDetectorApp_registerRecordDeviceDriver /devel/stage/R3.15.4/iocs/simdetectorioc-master
>>> 29.95user 0.02system 0:29.98elapsed 99%CPU (0avgtext+0avgdata 19256maxresident)k
>>> I think other calls to perl are awfully slow, too..
>>> Any idea why it might be so slow?
>> This sounds more like a problem with your Linux Mint system configuration than with the EPICS scripts, I run Linux Mint on my personal laptop at home and don’t see these kinds of issues.
>> I wonder if this may be related to different Locale settings. Is this slow:
>> time perl -CSD -e 'print "Hello\n"'
>> If yes, please try this
>> time perl -e ‘print "Hello\n"'
>> and then this
>> time perl -CSDL -e 'print "Hello\n"'
>> and this
>> time perl -C -e 'print "Hello\n"'
>> to see if the flags make any difference. What is your locale set to (echo $LANG) and maybe try changing it to see if that has any effect.
>> Please report any interesting findings back here...
>> HTH,
>> - Andrew
- registerRecordDeviceDriver.pl takes a long time to finish Hinko Kocevar
- Re: registerRecordDeviceDriver.pl takes a long time to finish Johnson, Andrew N.
- Re: registerRecordDeviceDriver.pl takes a long time to finish Henrique Almeida
Re: issue with epics in python Matt Newville
Record processing twice after upgrading to Base 3.15.5 Dunning, Michael
<2017>
2025
2026
Re: registerRecordDeviceDriver.pl takes a long time to finish Michael Davidsaver
<2017>
2025
2026
