Subject: Writing PVs from an amalgamated structure
To: EPICS Tech Talk <[email protected]>
Date: Fri, 6 Oct 2017 16:22:09 +0000
I need to create support for reading and writing a configuration file, but I also have to support non-EPICS environments.  I am thus considering making a library to be used in the IOC.  My present idea is to pass EPICS a pointer to a structure containing all the configuration options.  However, I do not know what best practices are for mapping PVs to the memory location.  What are the accepted methods?
Thank you,
Iain.
Re: Writing PVs from an amalgamated structure Johnson, Andrew N.
Prev: Asyn GPIB proto file exception @writetimeout jlarsson
Next: Re: Asyn GPIB proto file exception @writetimeout Zimoch Dirk (PSI)
Prev: Re: Asyn GPIB proto file exception @writetimeout jlarsson
Next: Re: Writing PVs from an amalgamated structure Johnson, Andrew N.
