Essentially, to install caQtDM, you need to edit caQtDM_Env file. There you see entries like this:
if [ -z "$QTHOME" ]; then export QTHOME=/usr;
fi
if [ -z "$QWTHOME" ]; then export QWTHOME=/usr;
fi
if [ -z "$QWTINCLUDE" ]; then export QWTINCLUDE=/usr/include/qwt;
fi
if [ -z "$QWTLIB" ]; then export QWTLIB=${QWTHOME}/lib64;
fi
if [ -z "$EPICS_BASE" ]; then export EPICS_BASE=/usr/local/epics/base-3.14.12.5;
fi
if [ -z "$EPICSINCLUDE" ]; then export EPICSINCLUDE=${EPICS_BASE}/include;
fi
if [ -z "$EPICSLIB" ]; then export EPICSLIB=${EPICS_BASE}/lib/$EPICS_HOST_ARCH;
fi
if [ -z "$EPICSEXTENSIONS" ]; then export EPICSEXTENSIONS=/usr/local/epics/extensions;
fi
if [ -z "$QTCONTROLS_LIBS" ]; then export QTCONTROLS_LIBS=`pwd`/caQtDM_Binaries;
fi
if [ -z "$CAQTDM_COLLECT" ]; then export CAQTDM_COLLECT=`pwd`/caQtDM_Binaries;
fi
export QTBASE=${QTCONTROLS_LIBS};
Based upon whichever the installed component and the path of them, you should be able to compile caQtDM. You can take a look at my VM to see how I did that; it’s good enough to make caQtDM working, if you still have a copy around.
I leave more detailed info (particularly the current version of caQtDM installation) to the real expert; I think they can give you more help.
> On Oct 17, 2017, at 2:33 PM, Antal, Szabolcs <[email protected]> wrote:
> Dear Folks,
> I’m in a bit of trouble with the installation of caQtDM-4.1.5 on Ubuntu 16.04.
> As the installation notes says the prerequisites are Qt5.x and qwt 6.1.x and Qt Designer (however I’m not sure whether I need Qt Designer if I have Qt Creator installed with Qt5.6.3).
> I managed to install Qt5.6.3 to /opt/Qt5.6.3/ and qwt6.1.3 at /usr/local/qwt-6.1.3/.
> I extracted the caQtDM archive to /usr/local/epics/extension/src/caqtdm-4.1.5.
> However I’m not sure how to set the configuration variables inside caQtDM_Env.
> Also a broken qt4 installation can be found on the system and it seems like the caQtDM_Build script tries to use that one
> during installation as I get the following error message when I run the script:
> qmake: could not exec '/usr/lib/x86_64-linux-gnu/qt4/bin/qmake': No such file or directory
> I’m a bit stuck at the moment, so any help regarding to the overall installation of caQtDM with the mentioned prerequisites
> would be greatly appreciated!
> Thank you in advance!
> Yours truly,
> ____________________
> Szabolcs Antal
> Software Developer
> <image002.png>
> evopro systems engineering Kft.
> member of the evopro group
> Ez az e-mail (ideértve annak bármely mellékletét) bizalmas információkat tartalmaz és jogi védelem alatt áll. Az üzenet kizárólag a címzett(ek)nek szól. Amennyiben Ön nem a küldemény címzettje, úgy a téves kézbesítést kérjük haladéktalanul jelezze e-mailben a feladónak és a teljes küldeményt helyreállíthatatlanul törölje. Amennyiben Ön nem az üzenet címzettje, kérjük ne készítsen másolatot az üzenetről, ne továbbítsa, ne tárja fel és ne tegye hozzáférhetővé azt más személy(ek) számára, továbbá semmilyen célra ne használja fel a bizalmas információt: ezen magatartások bármelyike a levéltitok megsértésének minősül.
> Information in this e-mail (including any attachment hereto) is confidential and may be legally privileged. It is intended solely for the attention of the addressee(s). If you received this message in error, please immediately notify the sender by return e-mail and irrecoverably delete the whole message. If you received this e-mail in error, please do not copy it, do not forward, disclose or make it available to other person(s), and do not use the confidential information for any purpose: any such action is regarded as a breach of confidence.
- Re: caQtDM installation help needed Pete Jemian
- caQtDM installation help needed Antal, Szabolcs
<2017>
2025
2026
<2017>
2025
2026
