1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: caputRecorder make error
To: "Zimoch Dirk (PSI)" <[email protected]>
Date: Thu, 19 Oct 2017 00:03:14 +0800 (GMT+08:00)
It seems your EPICS_HOST_ARCH environment variable is not set.
Dirk
Am 18.10.2017 um 15:52 schrieb l123173 <[email protected]>:
Hi all,
    I have installed synapps_5_8, base-3.15.3, centos 7.
    Base was ok. When I make synapps, caputRecordes has error, so I downloaded the newest caputRecorder from github( https://github.com/epics-modules/caputRecorder )
   Then I modified RELEASE in caputRecorder.
but  it said:  (base was in /opt/base-3.15.3)
[root@localhost caputRecorder-master]# make
/opt/base-3.15.3/configure/CONFIG:56: /opt/base-3.15.3/configure/os/CONFIG..Common: No such file or directory
make: *** No rule to make target `/opt/base-3.15.3/configure/os/CONFIG..Common'.  Stop.
How could I fixed it?
Thans,
Li xing
Re: caputRecorder make error Shen, Guobao
caputRecorder make error l123173
Re: caputRecorder make error Zimoch Dirk (PSI)
Prev: Re: caputRecorder make error Zimoch Dirk (PSI)
Next: Re: caputRecorder make error Shen, Guobao
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
