You are definitely not the first person to make this mistake, which I why I recognized it right away. We should probably print a better error message from devMotorAsyn than just reporting that the int32 interface is not found, providing
more of a hint as to what is probably wrong.
Sent: Tuesday, October 24, 2017 2:34 PM
To: Mark Rivers
Cc: EPICS mailing list
Subject: Re: Problems getting PI motors working
Is my face ever red.
Yes, I had the wrong ASYN port name in the database. I was referring to the TCP port not the motor port.
All working now. Sorry for the interruption!
That error about the int32 interface not being found is familiar. It is usually a problem with the database file, where the wrong asyn port name is used in the motor record INP link. It should be the port for the asynMotorController driver,
i.e. PIE873_1 or PIE873_1 in your case. But perhaps instead you have used the name of the underlying TCP port, i.e. pie873A or pie873B in your case?
- Problems getting PI motors working Eric Norum
- RE: Problems getting PI motors working Mark Rivers
- Re: Problems getting PI motors working Eric Norum
Re: Online EPICS training Andrew Johnson
<2017>
2025
2026
standard motion connections and pinouts Ernesto Paiser
<2017>
2025
2026
ANJ, 21 Dec 2017 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
