1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: medm sigsev on related display
To: Gerrit Kühn <[email protected]>, [email protected]
Date: Fri, 27 Oct 2017 10:46:56 +0900
There is a buffer overflow in "related display" with "a colum (or raw)
of buttons" visual. I reported to techtalk and already fixed in 3.1.13
which is available from github:
http://www.aps.anl.gov/epics/tech-talk/2017/msg00998.php
https://github.com/epics-extensions/medm/releases
# Indeed I'm using medm 3.1.11 on RHEL6 for production, and found the
problem when we were evaluating medm 3.1.11 on Ubuntu 1604.
best regards,
Shuei YAMADA
2017-10-25 23:55 GMT+09:00 Gerrit Kühn <[email protected]>:
> Hello,
> I found some issue here using medm 3.1.9:
> I'd like to use a "related display" with visual "a column of buttons".
> This works fine up to 14 labels. With adding the 15th label, I get a
> sigsev terminating medm. 15 items work fine using the "menu" visual, just
> the column of buttons appears to cause the issue. It also happens when
> starting off with a new screen, just containing this single related
> display.
> Can anyone reproduce this? Is this a bug (if so, where should I file it?),
> or am I doing something wrong?
> cu
>   Gerrit
                 Shuei Yamada,
                 High Energy Accelerator Research Organization (KEK)
                 mailto:[email protected]
Re: medm sigsev on related display Gerrit Kühn
Prev: Using the stream device @mismatch handler as an if conditional Paduan Donadio, Marcio
Next: Re: medm sigsev on related display Gerrit Kühn
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: medm sigsev on related display Gerrit Kühn
