Subject: Crosscompiling EPICS for ARM Arch - zedboard : Error
To: <[email protected]>
Cc: 김상균 소장님 <[email protected]>
Date: Wed, 1 Nov 2017 16:48:55 +0900
Hi.
I am attempting to build EPICS into Zedboard.
So I go through Tech-talk Messages.
I discover this recipe.
http://www.aps.anl.gov/epics/tech-talk/2016/msg00629.php
I attempt to cross-compile
First > gedit ~/.bashrc > export EPICS_BASE=/home/xilinx/epics/base
export EPICS_HOST_ARCH=linux-x86_64
export LANG=C
second > base.x.x.x/configure/CONFIG_SITE > CROSS_COMPILER_TARGET_ARCHS = linux-arm
        CROSS_COMPILER_HOST_ARCHS=linux-x86_64
Third > base.x.x.x/configure/os/CONFIG_SITE.Common.linux-x86_64 > #COMMANDLINE_LIBRARY = READLINE
Fourth > base.x.x.x/configure/os/CONFIG_SITE.linux-x86_64.linux-arm > GNU_DIR = /usr
        GNU_TARGET = arm-linux-gnueabi
Fifth > apt-get install libreadline6 libreadline6-dev gcc-arm-linux-gnueabi
Sixth > make
But It stops asLib.o
Error below.
clude/compiler/gcc -I../../../include/os/Linux -I../../../include        -I/usr/local/vw/zynq-2011.09/arm-xilinx-linux-gnueabi/include -c asLib.c
make[3]: /usr/local/vw/zynq-2011.09/bin/arm-xilinx-linux-gnueabi-gcc: Command not found
../../../configure/RULES_BUILD:229: recipe for target 'asLib.o' failed
make[3]: *** [asLib.o] Error 127
make[3]: Leaving directory '/home/xilinx/epics/base/src/libCom/O.linux-arm'
../../configure/RULES_ARCHS:58: recipe for target 'install.linux-arm' failed
make[2]: *** [install.linux-arm] Error 2
make[2]: Leaving directory '/home/xilinx/epics/base/src/libCom'
../configure/RULES_DIRS:84: recipe for target 'libCom.install' failed
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory '/home/xilinx/epics/base/src'
configure/RULES_DIRS:84: recipe for target 'src.install' failed
make: *** [src.install] Error 2
I do not understand where this route came from “/usr/local/vw/zynq-2011.09/bin/arm-xilinx-linux-gnueabi-gcc”.
How can I build successfully?
Thank you.
Dae Hee, Yoon
Re: Crosscompiling EPICS for ARM Arch - zedboard : Error Shuei YAMADA
Prev: Re: RTEMS+zoneset seems to be broken Ricardo Cardenes
Next: Data Conversion from CSS RDB Archiver to Archiver Appliance Abdalla Ahmad
Prev: Re: How to define a global variable and global array in python script for a widget of Control system studio (CS Anton Derbenev
Next: Re: Crosscompiling EPICS for ARM Arch - zedboard : Error Shuei YAMADA
