Subject: Re: concurrent put callbacks
To: "Andrew C. Starritt" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 2 Nov 2017 12:26:04 +0000
Would the SSCAN record record work for your application?  It does parallel CA put callbacks on the positioners and waits for them all to complete before triggering the next step.  In the Table mode you can give a positioner an arbitrary set of values.  But it does have constraints that would prevent it from working in some applications.
From: [email protected] <[email protected]> on behalf of Andrew C. Starritt <[email protected]>
Sent: Thursday, November 2, 2017 2:24 AM
To: [email protected]
Subject: concurrent put callbacks
Hi al,
The sseq record is great for doing a number of sequential actions that require a CA put callback before going on to the next step.
Is there an easy/recommended way a number of actions to run in parallel and then wait for all the CA put callbacks?
Andrew C. Starritt | Principal Controls Engineer | Australian Synchrotron
p: (03) 8540 4164 | f: (03) 8540 4200
[email protected]<mailto:[email protected]> | www.synchrotron.org.au
800 Blackburn Road, Clayton, Victoria 3168
concurrent put callbacks Andrew C. Starritt
Prev: concurrent put callbacks Andrew C. Starritt
Next: Re: Crosscompiling EPICS for ARM Arch - zedboard : Error Shuei YAMADA
Next: Re: concurrent put callbacks Mooney, Tim M.
