1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: A Problem : run it on the target board.
To: <[email protected]>
Date: Tue, 7 Nov 2017 10:40:23 +0900
Thanks to you, I solved the problem with cross-compile.
So, I moved it from Host os to taget board.
Because it has already been cross-compied.
And then
I tried to run the cross-compiled epics base on the target board.
root@plnx_arm:~/base/bin/linux-arm# ./softIoc
./softIoc: error while loading shared libraries: libdbRecStd.so: cannot open shared object file: No such file or directory
root@plnx_arm:~/base/bin/linux-x86_64# ./makeBaseApp.pl
Can't find EPICS base
But It failed.
Are there package files to add to the target board?
(I already put in besy-box, make, perl)
Should I do it differently?
I don’t know.
Thank you,
Dae Hee, Yoon
Re: A Problem : run it on the target board. Michael Davidsaver
Prev: Re: Compiling EPICS 3.15.4 with GCC 6.3.0 Andrew Johnson
Next: Re: A Problem : run it on the target board. Seung-hee Nam
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Compiling EPICS 3.15.4 with GCC 6.3.0 Jeong Han Lee
Next: Re: A Problem : run it on the target board. Michael Davidsaver
