1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Compile error with areaDetector
To: [email protected]
Date: Wed, 15 Nov 2017 08:26:09 +0100
I have run into a problem with areaDetector compilation when enabling EPICS4 using version 4.6.0 on Ubuntu16.04.3 LTS.
../ntndArrayConverter.cpp: In member function ‘void NTNDArrayConverter::fromUndefinedAttribute(epics::pvData::PVStructurePtr)’: ../ntndArrayConverter.cpp:497:54: error: no matching function for call to ‘std::tr1::shared_ptr<epics::pvData::PVField>::reset() const’
  dest->getSubField<PVUnion>("value")->get().reset();
In file included from /usr/include/c++/5/tr1/memory:50:0,
from /home/wuestenf/EPICS/EPICS-3.15.5/EPICS-CPP-4.6.0/pvDataCPP/include/pv/sharedPtr.h:124, from /home/wuestenf/EPICS/EPICS-3.15.5/EPICS-CPP-4.6.0/pvDataCPP/include/pv/pvType.h:41, from /home/wuestenf/EPICS/EPICS-3.15.5/EPICS-CPP-4.6.0/pvDataCPP/include/pv/pvDisplay.h:14, from /home/wuestenf/EPICS/EPICS-3.15.5/EPICS-CPP-4.6.0/normativeTypesCPP/include/pv/ntndarray.h:17,
  from ../ntndArrayConverter.h:2,
  from ../ntndArrayConverter.cpp:4:
/usr/include/c++/5/tr1/shared_ptr.h:644:7: note: candidate: void std::tr1::__shared_ptr<_Tp, _Lp>::reset() [with _Tp = epics::pvData::PVField; __gnu_cxx::_Lock_policy _Lp = (__gnu_cxx::_Lock_policy)2u] <near match>
  reset() // never throws
/usr/include/c++/5/tr1/shared_ptr.h:644:7: note: passing ‘const PVFieldPtr* {aka const std::tr1::shared_ptr<epics::pvData::PVField>*}’ as ‘this’ argument discards qualifiers /usr/include/c++/5/tr1/shared_ptr.h:649:9: note: candidate: template<class _Tp1> void std::tr1::__shared_ptr<_Tp, _Lp>::reset(_Tp1*) [with _Tp1 = _Tp1; _Tp = epics::pvData::PVField; __gnu_cxx::_Lock_policy _Lp = (__gnu_cxx::_Lock_policy)2u]
  reset(_Tp1* __p) // _Tp1 must be complete.
/usr/include/c++/5/tr1/shared_ptr.h:649:9: note: template argument deduction/substitution failed: ../ntndArrayConverter.cpp:497:54: note: candidate expects 1 argument, 0 provided
/usr/include/c++/5/tr1/shared_ptr.h:658:9: note: candidate: template<class _Tp1, class _Deleter> void std::tr1::__shared_ptr<_Tp, _Lp>::reset(_Tp1*, _Deleter) [with _Tp1 = _Tp1; _Deleter = _Deleter; _Tp = epics::pvData::PVField; __gnu_cxx::_Lock_policy _Lp = (__gnu_cxx::_Lock_policy)2u]
  reset(_Tp1* __p, _Deleter __d)
/usr/include/c++/5/tr1/shared_ptr.h:658:9: note: template argument deduction/substitution failed: ../ntndArrayConverter.cpp:497:54: note: candidate expects 2 arguments, 0 provided
The used gcc version is 5.4.0. On Ubuntu 14.04.5 LTS The error comes at the same line, but different problem:
../ntndArrayConverter.cpp: In member function ‘void NTNDArrayConverter::fromUndefinedAttribute(epics::pvData::PVStructurePtr)’: ../ntndArrayConverter.cpp:497:54: error: passing ‘const PVFieldPtr {aka const std::tr1::shared_ptr<epics::pvData::PVField>}’ as ‘this’ argument of ‘void std::tr1::__shared_ptr<_Tp, _Lp>::reset() [with _Tp = epics::pvData::PVField; __gnu_cxx::_Lock_policy _Lp = (__gnu_cxx::_Lock_policy)2u]’ discards qualifiers [-fpermissive]
here the used gcc version is 4.8. It look like an explicit typecast is necessary here. But what would be the correct type?
Jörn
Re: Compile error with areaDetector Mark Rivers
Prev: Re: Building AreaDetector from source Lang, Keenan C.
Next: Re: Building AreaDetector from source Stephen Molloy
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Building AreaDetector from source Stephen Molloy
Next: Re: Compile error with areaDetector Mark Rivers
