Subject: |
Possible bug in areaDetector/ADSupport/supportApp/nexusSrc/Makefile? |
Jörn Dreyer <[email protected]> |
To: |
[email protected] |
Date: |
Mon, 20 Nov 2017 14:09:04 +0100 |
on an Debian based Linux system I had some trouble to compile the areaDetector
module. In CONFIG_SITE.local one can define path variables for various
external components. In contrast to most Linux distributions I know, Debian
installs HDF5 in a sub path under /usr/include/hdf5 depending on the version
of HDF5 that is installed (serial, openmpi, openmpich...) So one has to set up
the correct path in CONFIG_SITE.local. By doing that at using the internal
version of Nexus, I discovered a problem in the Makefile. In this Makefile the
path's for HDF5, SZIP and ZLIB are added to USR_INCLUDES as
USR_INCLUDES += $(HDF5_INCLUDES)
While in all other Makefiles this is included as
USR_INCLUDES += -I$(HDF5_INCLUDES)
The compilation then fails with hdf5.h not found. After adding the -I I was
able to compile areaDetector on this system.
Jörn
- Re: Possible bug in areaDetector/ADSupport/supportApp/nexusSrc/Makefile? Mark Rivers
time stamp on vxWorks jumping to the future Dirk Zimoch
<2017>
2025
2026
Re: time stamp on vxWorks jumping to the future Zimoch Dirk (PSI)
<2017>
2025
2026
