1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Save MCA record data
To: <[email protected]>
Date: Wed, 13 Dec 2017 07:16:03 -0600
Abdalla:
On 12/13/2017 2:04 AM, Abdalla  Ahmad wrote:
> How to save mca record waveform data into any of the following formats:
> MCA, HDF5, NXS?
Attached is an example using Python with the PyEpics package to read the MCA waveform, and h5py to write the HDF5 NeXus file. You'll need to change the PV in the code to one of yours, of course. The waveform is stored in the HDF5 file at this address:
/entry/instrument/detector/waveform
but it is also available, by using an HDF5 hard link, at
/entry/data/data
The data is stored using GZIP compression, support for which should be available with all HDF5 clients. There are other possibilities. The output format has been validated with the "punx" NeXus data file validation tool.
I believe this example satisfies two of your three output formats.
You can view the resulting file with hdfview, PyMCA, or NeXPy.
Hope this helps,
   Pete
hdfview: https://support.hdfgroup.org/products/java/hdfview/
PyMCA: http://pymca.sourceforge.net/
NeXPy: https://nexpy.github.io/nexpy/
punx: http://punx.readthedocs.io
Hi
How to save mca record waveform data into any of the following formats: MCA, HDF5, NXS?
Best Regards,
Abdalla Ahmad
Control Engineer
SESAME
Allan, Jordan.
Tel: (+962-5) 3511348 , ext. 265
Fax: (+962-5) 3511423
Mob: (+962-7)88183296
www.sesame.org.jo <http://www.sesame.org.jo/>
Pete R. Jemian, Ph.D.                <[email protected]>
Beam line Controls and Data Acquisition, Group Leader
Advanced Photon Source,   Argonne National Laboratory
Argonne, IL  60439                   630 - 252 - 3189
   Education is the one thing for which people
      are willing to pay yet not receive.
import numpy as np
import h5py
import datetime
def write_nexus_file(fname, waveform, md={}):
	write the waveform to a NeXus HDF5 data file
	Parameters
	fname : str
		name of the file (relative or absolute) to be written
	waveform : numpy array
		the MCA waveform data
	md : dictionary
		key: value where value is something that can be written by h5py
			 (such as str, int, float, numpy array, ...)
	nexus = h5py.File(fname, "w")
	nexus.attrs["filename"] = fname
	nexus.attrs["file_time"] = str(datetime.datetime.now())
	nexus.attrs["creator"] = "write_nexus_file()"
	nexus.attrs["H5PY_VERSION"] = h5py.__version__
	# /entry
	nxentry = nexus.create_group("entry")
	nxentry.attrs["NX_class"] = "NXentry"
	nexus.attrs["default"] = nxentry.name
	# /entry/instrument
	nxinstrument = nxentry.create_group("instrument")
	nxinstrument.attrs["NX_class"] = "NXinstrument"
	# /entry/instrument/detector
	nxdetector = nxinstrument.create_group("detector")
	nxdetector.attrs["NX_class"] = "NXdetector"
	# /entry/instrument/detector/waveform
	ds = nxdetector.create_dataset("waveform", data=waveform, compression="gzip")
	ds.attrs["units"] = "counts"
	ds.attrs["target"] = "/entry/instrument/detector/waveform"
	# /entry/data
	nxdata = nxentry.create_group("data")
	nxdata.attrs["NX_class"] = "NXdata"
	nxentry.attrs["default"] = nxdata.name
	# /entry/data/data --> /entry/instrument/detector/waveform
	nxdata["data"] = nexus["/entry/instrument/detector/waveform"]
	nxdata.attrs["signal"] = "data"
	if len(md) > 0:
		# /entry/instrument/metadata (optional, for metadata)
		metadata = nxinstrument.create_group("metadata")
		metadata.attrs["NX_class"] = "NXcollection"
		for k, v in md.items():
			try:
				metadata.create_dataset(k, data=v)
			except Exception:
				metadata.create_dataset(k, data=str(v))
	nexus.close()
if __name__ == "__main__":
	demonstrate how to use this code
	Read MCA waveform from EPICS.
	import epics
	waveform = epics.caget("ioc:mca1")
	extra_information = dict(
		pv_name = epics.caget("ioc:mca1"),
		bitcoin_value="15000",		# just an example
	write_nexus_file("example.h5", img, md=extra_information)
Save MCA record data Abdalla Ahmad
Prev: Save MCA record data Abdalla Ahmad
Next: Re: Save MCA record data Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
