Subject: Re: aCalcout AVAL monitors
To: Bruno Martins <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 18 Dec 2017 20:34:38 +0000
Hi Bruno,
This seems a good improvement.  How about this: if any array element has changed by MDEL or larger, the array is posted with DBE_VALUE, and
if any array element has changed by ADEL or larger, the array is posted with DBE_LOG.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] <[email protected]> on behalf of Bruno Martins <[email protected]>
Sent: Monday, December 18, 2017 2:24:00 PM
To: [email protected]
Subject: aCalcout AVAL monitors
Hi everyone,
If VAL doesn't change between processings, acalcout doesn't post a monitor event to it, unless MDEL is set to -1 (as expected).
However, the same is not true for AVAL. Even with MDEL set to -1, if AVAL doesn't change I get no new monitor events. Here's the relevant code in the calc module:
https://github.com/epics-modules/calc/blob/master/calcApp/src/aCalcoutRecord.c#L983
This has come up before, and Tim Mooney explained it here:
So my question is: shouldn't AVAL's behavior follow VAL's? Or at the very least, shouldn't there be a mechanism to force AVAL to update?
Bruno
Re: aCalcout AVAL monitors Bruno Martins
Prev: aCalcout AVAL monitors Bruno Martins
Next: Re: aCalcout AVAL monitors Bruno Martins
